Multiple outputs
corndog71 · 3085
Offline corndog71
on: September 16, 2012, 11:03:33 AM
So I want to have 2 pairs of outputs.  From the posts I've read I know to bridge them with a 1K resistor on the center terminals.  What about the grounds?  The primary output ground tab has the resistor going to ground.  Do I just put a jumper between both ground tabs?
Rob
Reply #1 on: September 16, 2012, 11:45:01 AM
Jumper all grounds together.  You want them all at the same voltage, zero.
