So I wanted to do something different
corndog71 · 15898
Reply #30 on: February 19, 2013, 12:36:03 AM
Ooooooo... I like that!  I kind of pulled a similar trick on my brother when I Armaralled his CD.  I used a fake label, said "Bull Semen" like Sam Tellig did.
Offline underdawg
Reply #31 on: February 19, 2013, 05:06:11 AM
I would question how much load the meters would put on batteries when not in use, can be simply addressed with an on/off switch I would think.
« Last Edit: February 20, 2013, 04:43:59 AM by underdawg »
Reply #32 on: February 19, 2013, 08:41:40 PM
It kinda depends on whether they are VU meters, ammeters, or volt meters.
A VU meter or ammeter wouldn't need any switching unless there was backlighting, a voltmeter would be tricky to switch automatically, but it could tie in at the juncture where the 4K resistors go.
Offline corndog71
Reply #33 on: February 20, 2013, 02:49:08 AM
What about using a temporary switch with a voltmeter?
Rob
Offline underdawg
Reply #34 on: February 20, 2013, 04:45:11 AM
Sure a temp switch should work, but the key is not to have a load via the merters due to life of battery concern.
Reply #35 on: February 20, 2013, 06:58:02 AM
You can use a double-pole, 3-throw non-shorting switch to select which of the three batteries are being tested, or even a 6-throw version to test each of the 9-v separately. Each position can have its own series resistor to adjust the scale appropriately. Any meter movement up to 10mA will do; and you can calculate the resistor from a knowledge of Ohm's Law and the meter resistance. Install a push-button momentary-on switch so the meter is not used unless the button is pushed, and there will be no significant battery drain.
Offline corndog71
Reply #36 on: February 20, 2013, 10:00:06 AM
Actually, I'm more concerned about the life of the D cells.  Of course I could just incorporate a couple of test points on the front of the box and forget the meter. :P
Rob
