attenuators
John Roman · 24715
Offline howardnair
Reply #15 on: September 27, 2012, 04:02:29 PM
4krow
Reply #16 on: September 27, 2012, 04:17:36 PM
I had to double check, even though I 'knew' that I was right. Simply put, the in and out of your volume controls are wired in reverse. That means what would normally be 0 volume is now FULL volume. As you turn the control clockwise, the volume would Decrease, instead of Increase, because of the wiring of the volume controls.
Offline Laudanum
Reply #17 on: September 28, 2012, 02:40:39 AM
No worries D, how you doin?
J
Im doing pretty well, no complaints.  Thanks for asking.  Hope the same holds true for you.  Although, Im sure you'll be doing even better when you get those attenuators working   ;D
If you think about it, please post some impressions of the Goldpoints when you get some listening mileage in.   Thanks.
Desmond G.
Reply #18 on: September 28, 2012, 04:58:30 AM
Why does the wire from the selector switch enter the "Out" of the attenuator?  Wouldn't the wiper be the normal "out"?
Reply #19 on: September 28, 2012, 05:23:32 AM
With the series input resistance, wiring the output of the selector switch to the "out" of the volme control will still yield a variable resistor underneath the input series resistance.  Assuming the control is 15k, having the volume control right in the middle would set up 30K (or more) as the series input resistor and a 7.5k resistance to ground.  Moving the control all the way up would give you a 15k/15k, and all the way down would short the incoming signal.
Using the input terminal on the attenuator as the output just adds some series resistance between the attenauator and the grid of the 12AU7, but this resistance does not attenuate the signal.
The OP could try switching the input and output connections, I'd imagine that the problem would persist.
Reply #20 on: September 28, 2012, 07:25:45 AM
The Foreplay III is not wired as a normal attenuator. It's a shunt-more attenuator, and it's not a normal one of those either. This particular wiring sets it up so that a momentary failure of the switch contact removes the source; in a normal shunt mode connection such a failure acts as a momentary full-volume setting.
Actually, this is a variant of a classic "ladder" attenuator, which is (I'm sorry, it's not my fault!) NOT what is called a ladder attenuator today. You have to go back to the fifties to fine the classic ladder, which is a series of pi attenuators. It used to be the standard of quiet attenuators, used especially in live broadcast situations.
As you can see, there really are many attenuator wirings that are not "normal" but are still used in many situations.
Offline John Roman
Reply #21 on: September 28, 2012, 08:18:03 AM
Hello Paul,
Indeed the pre was working correctly prior to these changes. Prior to the GP install I modified the pre for use with 6SN7 output tubes. Paul J. posted:
"All the pins are different between the tubes. You have to wire the triodes as in the circuit diagram, which means you have to choose which triode is the voltage amplifier and which is the cathode follower. Once you have done that, you will know which grid takes its input from the level control." How do I determine that?
John
Regards,
John
Reply #22 on: September 28, 2012, 08:26:07 AM
Right, the FP III is the different kind of volume control.  The usual output is the input, the usual input is the output and ground is still ground.
I just refreshed my memory by looking at the schematic.
Offline Yoder
Reply #23 on: September 29, 2012, 11:42:38 AM
Hmmmm.... I built the following diagram with some help:
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwww.co-bw.com%2FImages_Audio_DIY%2FGold_Pt_Attent_Switch.jpg&hash=818f0c5e24bae580723f15bcccd63992bc1d5b91)
It also seems to follow DebK's images of her GP mods. But when I sat down and traced where the wires went, the attenuators connect to the "A" and "B" tubes which feed the RCA output jacks. So, in support of what Grainger says, the correct diagram should be (please correct me if I am wrong):
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwww.co-bw.com%2FImages_Audio_DIY%2FGold_Pt_Attent_Switch_New.jpg&hash=36c92d6c090bbcf95fd599df8e9e2ac062d087bd)
Reply #24 on: September 29, 2012, 05:14:13 PM
The top diagram is consistent with the schematic, but in actuality both diagrams will function in the preamp, with the bottom diagram providing constant input impedance, with the top schematic having better range (IMO).
The OP should check to be sure these controls have a variable resistance between GND and Out and Out and In through the rotation of the control.
« Last Edit: September 30, 2012, 07:01:40 AM by Caucasian Blackplate »
Offline John Roman
Reply #25 on: September 29, 2012, 08:03:25 PM
Thanks Yoder,
The new diagram was helpful.
John
Regards,
John
Offline Yoder
Reply #26 on: September 30, 2012, 09:21:22 AM
John: does it work now as it should? I have not tested mine yet. I am finishing up the Eros and then will start all of the testing of the Para's, FP III, and Eros...then the truth shall be revealed!
Offline John Roman
Reply #27 on: October 01, 2012, 08:58:18 AM
Hello Yoder,
Just got the pre working this morning. I had it wired using the upper diagram and had no volume control. I re-wired it using the lower diagram and volume control is normal for both channels. It seems fine now except I've picked some emi. I think the unshielded  wiring between the selector and attenuators is a possible cause? It was shielded in stock form so.....  any ideas for just shielding it?  piece of foil with a drain wire wrapped around it?
Thanks for the help,
John
Regards,
John
