I screwed up :/ help please!
balancedtriode · 4379
Offline balancedtriode
on: October 04, 2012, 03:54:36 AM
I was working on the power supply of my seduction and unknowingly dripped solder from terminal 25 to the chassis plate creating a short
I turned it on and the power supply sparked
I quickly shut It down and I am trying to find out what I need to replace.
are there any obvious suggestions for me to test or parts to replace,
any info would be appriciated
thanks,
coltrane
Thorens TD-160 Custom(rebuilt by me) with SME 3009 arm
Bottlehead Seduction
Extended Foreplay-III (build underway)
Stereomour Power Amp conversion (Heavily Modded)
Klipsch Cornwalls' with Vertical Horns
Reply #1 on: October 04, 2012, 04:19:16 AM
HA! fixed it should have
 waited to ask
thanks anyways
Reply #2 on: October 04, 2012, 04:39:50 AM
T25 to ground shorts the diodes only.  So if they are all good, you are good.  The capacitors shouldn't be affected.  Do check each diode.  Verify the voltage at T25.  It should be 160V DC.
