one thousand mic electrolytic
tubefrk · 6268
Offline tubefrk
on: October 23, 2012, 09:36:54 AM
Hello all, did I over hear someone talking about replacing the one thousand mic.  electrolytics in the Quicke with some film Caps??????
Offline corndog71
Reply #1 on: October 23, 2012, 10:27:28 AM
Yep, I built an alternate souped up version and replaced the 1000uF caps with Erse Pulse X 51uF 250V caps.  They are a LOT bigger caps.
Rob
Offline tubefrk
Reply #2 on: October 31, 2012, 10:40:47 AM
Thank you mister Dog.   Did you do anything to the circuit I need to know about?   Thanks,  Mike
Reply #3 on: October 31, 2012, 11:13:58 AM
You can go a bit lower than 1,000uF, I think PJ said 50uF or bigger is OK.  Voltage rating on this cap can be 5+ VDC.  FWIW, Parts Connexion has a ton of audio grade electroyltics that will work in this position, many of them are not particularly expensive (we used the 1000uF/35V cap because it was already in our inventory).
Offline corndog71
Reply #4 on: October 31, 2012, 02:46:49 PM
I went as low as PJ suggested with the idea that if it was lacking then I would go back higher.  I mostly wanted to try a film cap versus electrolytic.  But I've been really happy with the sound.  Bass lines are tight and well defined.  Music sounds a bit faster and livelier compared to the stock caps in my original quickie.  I'm still curious to try a higher value sometime down the road.  Maybe try some bypass caps.
Here's my overbuilt quickie:
http://www.bottlehead.com/smf/index.php/topic,3332.0.html
Rob
Reply #5 on: October 31, 2012, 05:50:43 PM
The bias voltage is about 2 volts. There are also those polymer electrolytics like OsCons that have a good reputation (low ESR up to high frequencies) and are available with low voltage specs like 4v. Normal practice with electrolytics is to run them at 50% to 80% of rated voltage; however the only documented problem with lower voltage is that they can lose their high voltage capability - you can't take the 35v cap out of a Quickie and count on it to take 30v in a SEX amp.
There are some lower-voltage Mylar caps that are small with high capacitance, and not too expensive. They might be worth listening to.
Reply #6 on: November 01, 2012, 03:12:52 AM
   .  .  .    the only documented problem with lower voltage is that they can lose their high voltage capability - you can't take the 35v cap out of a Quickie and count on it to take 30v in a SEX amp.   .   .   .
Would this be a case of capacitor forming?
Offline earwaxxer
Reply #7 on: November 01, 2012, 06:05:14 AM
I first replaced the electrolytic with a Elna Silmic ll that I had laying around. Then I went with the Mundorf MKP 56uF. I think I remember an improvement in sound with the film. I'm sticking with the MKP. Not sure if it makes sense going crazy on this cap.
Eric
Offline E.T.
Reply #8 on: November 01, 2012, 07:27:27 AM
Do you happen to gotta list of said audio-grade electrolytics?  I've used Elna Silmic II's and I think they sound real purty, but that's the only brand I know of.
Offline earwaxxer
Reply #9 on: November 01, 2012, 07:36:22 AM
Parts Connection has the good stuff! I'm not sure you will do significantly better than the Elna, in an electrolytic. I would go film.
Here is an electrolytic cap test:
http://tech.juaneda.com/en/articles/electrolyticcapacitors.html
Eric
Offline corndog71
Reply #10 on: November 01, 2012, 11:58:32 AM
The reason I wanted to try a film cap was because the ESR is typically a fraction of what you'll find from an electrolytic cap.  I'm no expert but I've read with regards to power supplies that keeping the ESR low is desirable.   I'm pretty sure I hear a difference.
Rob
