Ok, I guess I can jump in here with my experiments.
I purchased the quickie with PJCCS but decided to build it stock first. I was very impressed by how quiet it was. It was instantly better than my modded Foreplay II. The tubes provided sounded good but were very sensitive to my fingers and bumping the attached cables and rang easily with any vibration. They do settle down after a couple of seconds and just get back to making music. As good as it was I knew from many years of playing with my various Foreplay tweaks that there was room for improvement.
PJCCS - Ah, now we're getting somewhere! This made a very nice difference adding a bit better focus to the soundstage, tighter bass, and just a fuller sound.
Output Caps - After the power supply this is the most noticeable area of improvement.
1. Sonicaps (Gen 1) - These brought much better resolution over the stock caps, more air between instruments, better dynamics, tighter and better defined bass. These run on the slightly brighter side of neutral and so provide less of the tube warmth many people like. If you like a leaner and closer to solid state sound then consider these.
2. Clarity Cap ESA Series - These are very interesting and unique caps. Both detailed and dynamic but with a very warm overall sound. This is particularly noticeable on the higher frequencies. If you have bright sounding speakers then these may just be the ticket for you. I really love these in my S.e.X. Amp. I really liked them in my Quickie but was very curious about trying the next step up in Clarity's line up.
3. Clarity Cap MR Series - Holy &$%#! My jaw hung, mouth agape, and I was just stunned at how much more information I was hearing! Yes, you will pay a price for it but considering the low cost of the Quickie it's not too bad of a hit to the wallet. One small caveat, they do take a few hundred hours to sound their best but even early on they were an immediate improvement over the ESA caps. Older recordings seemed blown up in space and resolution. Cliche as it sounds I heard stuff in familiar recordings that went previously unnoticed. I could go on and on about these.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2FBottlehead%2520Quickie%2Fb374d05f.jpg&hash=de345e669b2e3a5ffd9142e663d2aab9f26992b4)
Vibration control - Initially I borrowed the wood base from my Foreplay II as the plates are the same size. This certainly made my Quickie look nicer but did nothing to suppress vibration. I happened to have some foam bricks used for shipping expensive servors handy so I cut one to just a little wider than the wood base.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2FBottlehead%2520Quickie%2F8f408d8e.jpg&hash=6c76acf7c5d24345a46495d9589669f390618f15)
But then I thought I'd go simpler.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2FBottlehead%2520Quickie%2F7669d368.jpg&hash=14b914bb8c19b18960f72b60edc627e4bdfe9618)
That helped some but still not perfect. Eventually I decided to splurge on a pair of Herbie's Tube Dampers. Now we're getting somewhere. At first I didn't really hear much of a difference. Then I tried some different tubes with and without the damper rings and noticed that they did help cut down on the ringing. I had to bend them smaller to get them to fit the tubes even though they were supposed to fit the 3S4. Not a bad tweak for the money but not a necessity. Unless you're like me and want to cover every base.
That's pretty much all I did with my stock Quickie. Eventually I wanted to build an all out Quickie as I had lots of ideas on how to take the design further.
Here's a list of features on the Ultimate Quickie:
1. 3"x10"x17" Hammond aluminum box and lid
2. a sheet of Dynamat Extreme
3. Erse Pulse X film caps for the power supply
4. Goldpoint selector switch for switching the signal and ground of each input
5. PRP Resistors in the power supply
6. Two D-Cell holders per channel wired in parallel for longer play time
7. 16AWG wire for power supply connections (I know, total overkill here!
8. Homegrownaudio 22AWG cotton-insulated and teflon-insulated silver wire for signal
9. Three Power Sonic rechargeable 12V/5Ah SLA batteries for 36VDC supply
10. PEC 100K Volume Pots
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2FBottlehead%2520Quickie%2FIMG_6781_zpsea11e3b9.jpg&hash=ee9559a73dae99b92fc83ee60c0b9eb8030be700)
With the previously mentioned Clarity MR caps this turned into quite the project. Since all of this came together at once it's hard to say where improvements came from. Well, the Dynamat really cuts down on ringing from the tubes as does the boxed design. Now my fingers don't get close to the tubes when I'm fiddling with any of the controls. I don't bump into the cables anymore since they're all in the back which also helps avoid ringing. I really think the film caps cleaned up the sound vs. the stock electrolytics. The music seems more lifelike and faster. In the end I think it sounds fantastic and well worth my efforts.
