Quickie mods
earwaxxer · 227047
Offline charger
Reply #165 on: August 22, 2013, 11:41:46 PM
sometime the Q pick up some noise such for example mobile interference , is there a way to stop it ?
Oppo 980H - PC - Arcam rDac- Bottlehead Quickie- Abletec ALC040 - Signal cables Atlas Element Integra-speakers cables Tellerium Q black-Martin Logan Motion 15
Offline corndog71
Reply #166 on: August 23, 2013, 07:10:17 AM
Keep your phone away from it.
Rob
Offline charger
Reply #167 on: August 23, 2013, 09:14:31 PM
it pick up even in long distance
4krow
Reply #168 on: August 24, 2013, 04:28:56 AM
 It might need to be shielded. Guys, what do you think of this? Maybe a part is acting as an antennae.
Offline earwaxxer
Reply #169 on: August 24, 2013, 01:17:30 PM
The Q is SUPER micro-phonic. Thats her nature. You have to try different thinks, shielding, damping of the chassis, position away from sources, etc. That goes with tubes. Plug and play is what we get this transistors. We use tubes for other reasons.
Eric
Reply #170 on: August 24, 2013, 02:26:19 PM
We have not experimented with extreme measures to kill unwanted RF interference, but here is an approach that might be effective:
1) put a small NPO ceramic cap, 27pF to 100pF, from tube grid (pin 3) to cathode (pin5). This shorts the RF energy so that it cannot appear between grid and cathode.
2) (optional) another small cap, around twice as large (56 to 220pF?) from pin5 to ground - this bypasses the cathode bypass cap to take that energy to ground.
Ceramic capacitors perform well at very high radio frequencies; and alternative is silver-mica caps. You want a physically small cap as well, so that it does not act as much of an antenna by itself.
Of course, replacing the chassis plate with a metal one, and fitting it into a metal box in place of the wood frame, and installing a tube shield, will shield all the circuitry, which may also help.
4krow
Reply #171 on: August 24, 2013, 06:16:50 PM
 Thanks Paul, now don't get me thinkin' too much. RF is all around us, NOW more than ever! No surprise that it can haunt our systems and brains. Might be time to sell those tin foil hats that I stored in the garage in case of alien attack.
Offline charger
Reply #172 on: August 24, 2013, 10:43:25 PM
I will try Paul advice on putting ceramic caps, but will this affect the sound ?
4krow
Reply #173 on: August 25, 2013, 12:10:12 AM
 I doubt it, since the cap is of a value that is not in the range of hearing. and if I got it right, it goes to ground.
Offline charger
Reply #174 on: August 25, 2013, 06:01:59 AM
why this was not included in the original stock project?
4krow
Reply #175 on: August 25, 2013, 08:23:04 AM
 Maybe you can only give so much for the money. I do upgrades on some Carver circuits, and while I could do more for a given circuit, I simply would have to charge more. Now, having said that, I do see your point. RFI is eveeeryahere!. When I used to work in central offices for the phone comp[nay, you could feeel the singing of the equipment . I was not totally comfortable in microwave sites.  But as bad as it is, some parts of the country are definately worse than others, just like dirty power.
Offline adamct
  • Maxxximum CAPacity Crack
Reply #176 on: August 25, 2013, 09:23:05 AM
Presumably because lots of people don't need it, and it wouldn't make sense to add a part and increase the cost of the kit for everyone, to address a problem only experienced by a few.
Offline Wanderer
Reply #177 on: August 25, 2013, 10:13:03 AM
+1 on that thought.
One of the things you win building kits in general and Bottlehead in particular is the abilty to do simple mods to make a unit fit your particular needs.  I have never had an rf issue with my Quickie. I have modded mine to a headphone amp, tried the plate chokes, tried the PJCCS and prefer it to chokes. None of this fussing about would be so painless with an off-the-shelf unit.
Kevin R-M
Reply #178 on: August 25, 2013, 04:32:48 PM
I have chosen values that will not affect audio frequencies. Worst case is a corner at 64kHz.
Reply #179 on: August 25, 2013, 04:38:59 PM
Normally this is not a problem. In classic circuits, such an RFI control cap is only occasionally used (Marantz for instance) and even then, only for very high-gain phono preamp circuits, not for preamps and amps. I think this is the first time I've posted this idea, possibly the second time, in 15+ years of active posting.
