Seduction with Stereomour?
Downhome Upstate · 37483
Online Paul Joppa
Reply #15 on: November 08, 2012, 11:21:46 AM
I recommend you experiment with the stepup ratio; the cartridge/transformer interaction is complex and difficult to predict. For example, the DL-103 is said to have 100 ohms impedance, which stepped up by 20:1 (26dB) becomes 40K ohms. Running that into the 47K Seduction input gives a net 21dB gain - and also provides nearly 1:1 damping. This is what I would use to start with, and gives about the most gain you can get from a transformer into the stock (RIAA standard) 47K load. Transformer ratios of 20-30dB won't change the net actual gain more than a dB or so, but they will change the cartridge damping and the transformer's high frequency behavior.
Of course, I got the 100 ohm figure for the DL103 off the internet, I didn't measure it myself, so I can't be sure it's correct.
Offline Downhome Upstate
Reply #16 on: November 08, 2012, 11:30:48 AM
I believe I read in a few places that the SUT will see the DL-103 as presenting 40 ohms. I'll have to go back and look again.
"Too soon old;
   Too late schmart"
    The late Mr. Fox, Fox's Deli, Rochester, NY
Mike P.
Reply #17 on: November 08, 2012, 11:38:58 AM
What is the difference between a cartridge's output impedence (40 ohms for the DL-103) and load impedance (100 ohms)?
"Too soon old;
   Too late schmart"
Mike P.
Online Paul Joppa
Reply #18 on: November 08, 2012, 12:10:15 PM
That sounds more reasonable, actually. In that case, the 30dB turns ratio would give 25dB net, probably best for Seduction - if the damping and transformer HF response are good.
Guess I should just stick with the recommendation to try different ratios once you have the transformer.
Reply #19 on: January 20, 2013, 03:43:34 PM
Just placed my Seduction order - looking forward to it! Hey, Doc, where's that photo with the model holding the Seduction at thorax level? That is such a great picture!
An Asylum inmate is selling me his armless Kenwood KD-500 'table for $150. I've got a Jelco SA-750DB for it: I'll need to drill out the existing armboard to 30 mm. He's also sending over a Hammond box with Cinemag 3440's, currently wired at 1:30/37.5 Ohms. Think I'll try the 1:18, 150 ohm setting when I plunk down for a DL-103 or 103R.
Addictive, this is. Gotta love it.
"Too soon old;
   Too late schmart"
Mike P.
Reply #20 on: January 21, 2013, 03:34:52 AM
Back some months ago I was using my vintage DL-103C with my setup.  I have a buddy using a new DL-103 with my old Seduction and my Denon SUT.  Both worked perfectly with the Denon SUT.  Right now I am out of town so I can't look up the specs on it.
BTW, Paul Joppa gave some good information about the needed turns ratios and impedances on transformers some time back.  I expect it is in the phono folder.
« Last Edit: January 21, 2013, 03:37:32 AM by Grainger49 »
Reply #21 on: January 21, 2013, 06:42:43 AM
Do you remember the turns ratio used with the Denon SUT?
"Too soon old;
   Too late schmart"
Mike P.
Reply #22 on: January 21, 2013, 07:00:30 AM
The DL-103R has ~0.25mV of output, the DL-103 0.3mV.
I've successfully used a Seduction with cartridges rated at 6.8mV, and the balance of gain was outstanding.  To get there with 0.25mV, you'd want a voltage step-up of about 1:20.
With a voltage step-up of 1:30, you'll end up with ~7.5mV, which is potentially too much, but give it a try anyway, on that Cinemag unit, it's more like 1:36, which will push it even higher.  I think the 1:18 should work really well!
Reply #23 on: January 21, 2013, 11:03:43 AM
I'll mark this thread unread and look up the specs when I get back home.
Online Paul Joppa
Reply #24 on: January 21, 2013, 11:44:12 AM
I don't have the numbers handy, but as I recall the DL-103 has a DC resistance comparable to the resistive impedance load presented by the stepup transformer/Seduction combination. That means a substantial signal reduction; if the resistances are matched it cuts the voltage in half (-6dB). Some enthusiasts think that is a good option, providing some damping of the vinyl/tip mass resonance.
Reply #25 on: January 22, 2013, 02:30:52 PM
It seems that the instructions ended up with my friend who is borrowing the SUT right now.  I will contact him tonight and see if he can locate the specs.
Reply #26 on: January 25, 2013, 01:34:55 PM
I have determined that discretion is the better part of valor here.  Accordingly, I will be advancing to the rear, with dignity.
Placed an order for the Audio Technica AT7V, a low compliance, low tip mass MM design with 5 mv out that should be a great match for the Jelco arm and the Seduction.
God willing, I will live to screw around with LOMC cartridge loading another day.
"Too soon old;
   Too late schmart"
Mike P.
