Quickie Capacitor Question
Cary · 11146
Reply #15 on: November 26, 2012, 04:18:13 PM
Reply #16 on: November 26, 2012, 04:58:57 PM
Thanks, didn't see that.  I also didn't realize the Zo was 4k with pjccs.
Jim
Offline Lee Hankins
Reply #17 on: December 13, 2012, 01:49:25 PM
Dan,
Why did you recommended the Solen SB270 (2.7uf 150v) caps for the quickie instead of the "normal" SY220 (2.2uf 250v) Solen caps, only $1 difference.
Cordially,
Lee Hankins
Lee Hankins
"End of the Road"
Homer, Alaska
Offline earwaxxer
Reply #18 on: December 13, 2012, 02:35:05 PM
Hi Lee - Cap choice is a big topic. Here is a link that many refer to when choosing caps.
http://www.humblehomemadehifi.com/Cap.html
cheers - Eric
Eric
Reply #19 on: December 13, 2012, 02:44:07 PM
Dan,
Cordially,
Lee Hankins
Just because they have a bit more capacitance for about the same price and you certainly don't need the higher voltage rating. The 2.2 250V was the original value spec'd just because it is a part we already stocked for Foreplay III. Though I haven't done the comparison myself, some say that the thinner dielectric in the cap with the lower voltage rating sounds a little bit better.
Offline boulos
Reply #20 on: January 12, 2014, 07:23:43 AM
Would the SB270 Solen caps be a good choice for the Quickie 1.1 also?
Reply #21 on: January 12, 2014, 08:47:05 AM
Sure, those are a great choice for the coupling caps.
Offline Moot
Reply #22 on: January 26, 2014, 11:35:29 PM
If I want to try various output caps, do I want to stay with lower ratings (35v) or higher ratings (1000v)? Let's assume price isn't a consideration.
Reply #23 on: January 27, 2014, 02:37:41 AM
The Quickie power supply is 36V coming from the batteries.  The output capacitor will not see all of that for more than a second or 5 seconds.  Nothing higher is necessary.
But, the better film caps start around 200V.  Some are only available with a 600V rating.
Just be aware how much larger film will be and use the lead length to your advantage.
« Last Edit: March 31, 2014, 03:43:03 AM by Grainger49 »
Offline Moot
Reply #24 on: January 27, 2014, 06:49:58 AM
Thanks, Grainger49! So I was guessing that the lower the voltage rating the thinner the dielectric, and the thinner the dielectric the better it sounds. It's good to know I can try out some of the fancy caps!
Reply #25 on: January 27, 2014, 06:53:55 AM
I don't know that thin makes for better sound.  The only thing I know you lose with higher voltage ratings is money and space.
In general film caps (usually thicker dielectric) will sound better than electrolytic caps (stock with thin dielectric) when in the audio path.
« Last Edit: March 31, 2014, 03:39:36 AM by Grainger49 »
