Quickie pot question
balancedtriode · 2782
Offline balancedtriode
on: November 23, 2012, 04:12:12 PM
hey I have two high end mono 10k pots' I would like to use  them in quickie instead of the stereo 100k pot, will they work? or will the negative effects out weigh the positives effects?
Thorens TD-160 Custom(rebuilt by me) with SME 3009 arm
Bottlehead Seduction
Extended Foreplay-III (build underway)
Stereomour Power Amp conversion (Heavily Modded)
Klipsch Cornwalls' with Vertical Horns
Reply #1 on: November 23, 2012, 07:25:12 PM
As long as your sources will drive the (relatively low) 10K impedance, they should work fine. But 10K is pretty low for a Seduction. If you do, increase the Seduction output capacitor to 1uFor more.
« Last Edit: November 23, 2012, 07:27:11 PM by Paul Joppa »
