help with PT-2 install on Paramour I
jeff g · 12419
Reply #15 on: November 25, 2012, 06:47:47 PM
This is grounding the center of the 6.3V winding, not the transformer itself.
Offline jeff g
Reply #16 on: November 26, 2012, 12:13:21 PM
thanks - I'll run a separate wire from the 6.3 v to T9 on the amp.
Offline jeff g
Reply #17 on: December 01, 2012, 07:04:41 AM
ok, everything is connected following directions above.
when doing the resistance checks, almost all are close to the manual, with the exception of T1 and T2 (the hi-v connections from the PT2).
these are supposed to be 215-240 ohms.  they measure 94 k ohms.
any suggestions?
Reply #18 on: December 01, 2012, 07:23:12 AM
You're good to proceed to voltages.  Those would have seen half of the resistance of the high voltage transformer winding (since the center was grounded), but without this connection, that resistance value will change.
Offline jeff g
Reply #19 on: December 04, 2012, 03:00:59 PM
got it hooked up and playing music.  everything seems to be working fine.  Thanks very much for your patience and assistance Paul - it's much appreciated.  Jeff
Reply #20 on: December 04, 2012, 05:26:22 PM
No problem Jeff, I'm glad everything worked out nicely.
