Interesting ebay find
dmannnnn · 15246
Offline dmannnnn
on: January 08, 2010, 08:13:22 PM
They arrived today.  A pair of surplus 35 position rotary switches, shorting style, unused.  These look like they came off a control panel from a Siberian Nuclear power plant.  Not the smoothest mechanism, but not too bad either.  They are 3.5" a side and 3" deep.  I will report back on them once I can get them loaded with resistors.  It might be awhile though.  If they can hold the contact well while switching they should work out pretty good.
Price on these is $34/pair shipped.  I was thinking of a passive preamp in a bottlehead size chassis.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fimg39.imageshack.us%2Fimg39%2F8502%2Fpairz.jpg&hash=d85d13767e21f475b9818ce13b91db3caa6fd4c2)
Close up of contact mechanism
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fimg33.imageshack.us%2Fimg33%2F8420%2Fp1010007ym.jpg&hash=528639d02ca7e1118d9235c43d7152334e0e20a1)
http://cgi.ebay.com/Powerful-rotary-sliding-switch-35-steps-2-discs-2-PCS_W0QQitemZ250453363226QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a502f0a1a
Harmon Kardon T60 - Hagerman Bugle - Cal Audio Labs CL15
ForePlayIII - Paramount 300B's
Klipsch RF-7/Altec Model 14/Magnepan MG12
Reply #1 on: January 09, 2010, 12:30:57 AM
Booger!  Those are industrial all right.  They look like the stuff in the first mill I worked in.  All the machinery had been built in 1942, built to last a hundred years.  Serious stuf there!  The controls were mounted on 2" thick slate panels.
Do you mean make before break when you said shorting?  I'm interested in a pair.
« Last Edit: October 12, 2010, 03:44:17 AM by Grainger49 »
Offline ssssly
Reply #2 on: January 09, 2010, 02:02:03 AM
Now those are some beefy rotary switches. You could use non inductive wirewounds to populate that thing.
Offline dmannnnn
Reply #3 on: January 09, 2010, 10:25:18 AM
Yes they are make before break.  You can see the wiper spanning both contacts while switching.  I tried to test them with the DMM and it seems to be okay.  I won't know if they switch without noise until I get a signal going through them.
Reply #4 on: January 09, 2010, 11:19:46 AM
I don't care if I don't need them.  They look so cool I'll have to order a pair.
Offline Mudhiker
Reply #5 on: January 09, 2010, 05:33:26 PM
Just pulled the trigger.  Now I gotta figure out how to calculate all the resistors to populate them with.  Most of the online calculators I've seen are for 24 step attenuators.
Isaac Gorton
Offline dmannnnn
Reply #6 on: January 09, 2010, 09:43:24 PM
Post a link if you find a good calculator.
Offline ssssly
Reply #7 on: January 09, 2010, 11:37:46 PM
I wonder what these were initially used for? We will probably all end up on some sort of watchlist for buying Russian reactor parts or the like.
Reply #8 on: January 10, 2010, 01:52:11 PM
VoltSedond's Attenuator page has a calculator for resistor values.  It has a tab on the excel spreadsheet for different kinds of attenuators.  The advantage of the S5 is it only has 2 resistors in the audio path at a time.  It takes the number of steps and one more resistor.
http://www.siteswithstyle.com/VoltSecond/12_posistion_shunt/12_Position_Pure_Shunt.html
It is the Zip file in magenta about 1/2 way down the page.
« Last Edit: October 12, 2010, 03:45:51 AM by Grainger49 »
Offline Mudhiker
Reply #9 on: February 01, 2010, 03:15:51 PM
They just arrived today. These things are MASSIVE!  I was planning on putting them in a 2u chassis but it's gonna hafta be a 3u.
Isaac Gorton
Reply #10 on: February 02, 2010, 12:27:37 AM
Mudhiker,
I have been watching some just because I want to do this when I get my next temp job.  I had imagined they were large but I have no idea how large.
Can you post a picture showing one next to a quarter?  A Bottlehead product?
(changed my avatar since everybody in the thread has his dog)
« Last Edit: April 28, 2010, 02:19:45 PM by Grainger49 »
Offline ssssly
Reply #11 on: February 19, 2010, 01:22:33 AM
Has anyone populated one of these monsters yet? They look big enough to use tantalum resistors in them.
Offline dmannnnn
Reply #12 on: February 19, 2010, 09:11:09 AM
I haven't touched them yet.  In the middle of a foreclosure. :-( Probably won't be til later this year unless I get a wild hair.
Offline dmannnnn
Reply #13 on: February 19, 2010, 09:16:45 AM
VoltSedond's Attenuator page has a calculator for resistor values.  It has a tab on the excel spreadsheet for different kinds of attenuators.  The advantage of the S5 is it only has 2 resistors in the audio path at a time, but takes twice as many resistors..
Actually, the S5 configuration only adds one resistor to a standard stepped attenuator.  It uses a single resistor for each step with an additional fixed input resistor.  These can be made with a single pole (layer) switch.  The 'ladder style' configuration switches the input resistor and uses 2 resistors in each step.  This requires a 2 pole switch.
Reply #14 on: April 28, 2010, 02:20:32 PM
Yup, I wasn't thinking well.
