is there an easy way to sum the channels for mono?
denti alligator · 34343
Offline Brent
Reply #15 on: January 28, 2013, 08:28:45 AM
Paul,
Just to clarify:  are you saying one could leave the existing wiring as is, and just add a loop from T26 to T36 with a SPST switch in it?  Open = stereo, and closed = mono? That seems to be different from what Grainger is suggesting, and I want be sure before I do anything.  Also, my Seduction is from six or seven years ago--has the circuit and numbering been static since then, or do I need to adjust?  There is a post on the old BH forum on AA that suggests a switch connecting T29&T39, which is partly why I ask.
Brent
P.S. I hope this is okay to ask in this thread instead of starting another one.
Offline Brent
Reply #17 on: January 28, 2013, 09:20:49 AM
Brent,
I just helped Denti Alligator through just this.  I can send you the instructions and the sketch I made if you like.
Offline Brent
Reply #18 on: January 28, 2013, 09:47:35 AM
Grainger, thanks.  PM sent.
Offline denti alligator
Reply #19 on: January 28, 2013, 10:55:03 AM
It was a cinch. Thanks Grainger!
I have one related question: someone on another forum said he always switches his phono pre to mono for artificially made stereo recordings. So I'm thinking: will that really work? I mean, if I take a stereo pressing of Rubber Soul and switch my Seduction to mono (summing the channels), will it sound exactly like a mono pressing of Rubber Soul (since that was the original). This might convince me to get those new Beatles vinyl reissues!
- Sam
Reply #20 on: January 28, 2013, 10:59:50 AM
Yes, it works.  It is particularly handy with early Beatles stereo.  The four lads are in one speaker with all instrumentation in the other.  It is awful sounding without a mono switch.
However, the mono mix of early Beatles and stereo mix are different.  So you won't get the exact sound that the mono mix gives.
Reply #21 on: January 28, 2013, 11:16:16 AM
Paul,
Just to clarify:  are you saying one could leave the existing wiring as is, and just add a loop from T26 to T36 with a SPST switch in it?  Open = stereo, and closed = mono? That seems to be different from what Grainger is suggesting, and I want be sure before I do anything.  Also, my Seduction is from six or seven years ago--has the circuit and numbering been static since then, or do I need to adjust?  There is a post on the old BH forum on AA that suggests a switch connecting T29&T39, which is partly why I ask...
Yes.
Either set  (26/36 or 29/39) will work, but using 26/36 keeps the plate voltage out of the switch, reducing the chance of audible switch transients.
Reply #22 on: January 28, 2013, 11:33:25 AM
That's what I feared. Why oh why did they reissue the stereo mixes on vinyl??
- Sam
Reply #23 on: January 28, 2013, 01:47:06 PM
I believe the summed stereo will sound considerably better than the straight stereo.
Offline Brent
Reply #24 on: January 28, 2013, 05:30:20 PM
Thanks everyone for the help.
denti, FWIW, a Beatles mono vinyl box is supposedly to be released sometime in 2013. It would be nice if they'd release individual albums in mono too.  They didn't do that with the mono CDs though, so I'm not holding my breath.
Cheers,
Brent
