OT-1 backwards?
ssssly · 3464
Offline ssssly
on: February 11, 2013, 01:09:58 AM
The OT-1 transformer that came with my kit seems to be upside down from what is shown in the instruction manual.
Instead of the top row of lugs going from 1-5 and the bottom row going from 6-10...
The top row goes from 6-10 and the bottom 1-5.
It is also missing lugs on 2 and 6 where the one in the manual has them.
I wired it as in the manual for 8 ohm output according to the terminal numbers.
Just wondering if this is the correct way or if I should have made it look like the one in the manual? Mine is a mirror image of the manual when you look at it.
Offline ssssly
Reply #1 on: February 11, 2013, 09:35:22 PM
Or what should the readings be at OT-1s different lugs so I can test to see if it is wired right?
Online Paul Birkeland
Reply #2 on: February 12, 2013, 03:42:41 AM
I'd stick to the numbers on the plastic bobbin.  There have been a handful over the years that were put in the channel frames upside down.
Offline ssssly
Reply #3 on: February 12, 2013, 03:58:52 PM
That's what I figured.
