Built my Crack, but have some buzzing I can't figure out.
BaksideAttak · 6520
Offline BaksideAttak
Hi all,
I built my Crack plus Speedball about three weeks ago, and it sounds great with one exception - some slight buzz. I've been trying to get access to the forums to get technical assistance from some of you gurus, so I would really appreciate some insight into the issue. I will go ahead and try and give you all the information I have, though some of it may be irrelevant:
  • After building the Crack (base, no Speedball), it passed all resistance and voltage tests within 10% of target
  • When plugging in my heaphones without music, I heard a very low buzzing. This buzzing DOES change with turning of the volume knob.
  • https://mega.co.nz/#!VQtS0JQY!CdVUcU5epwLMN_wx3lqJLAlto15Wdx1PoqsN-7EMKNo This is a link to an audio recording of the buzzing. I put my iPhone up to my headphones and recorded, and it captured the buzz pretty well. Note that this was captured at full volume of the Crack
  • I was hoping that this could be an issue that could be resolved by installing the Speedball upgrade. I did so, passed all voltage and resistance checks within 10% margin of target. The buzz was still there (but the amp sounded a LOT better after Speedball! I was very impressed.)
  • I tried cleaning the tube pins by removing and reinserting several times.
  • I went through the manual for both the base Crack and Speedball three times to ensure each connection was in the right place.
  • I then tried reheating all the solder joins and retesting the resistance and voltages. Everything checked out within 10% again.
  • In case that last step wasn't enough, I reheated and added a little more solder to the joints to ensure connectivity. Resistance and voltages checked out, but the buzz is still there.
  • I tried several cables, another amp, and removed my DAC from the setup, and the problem seems isolated to the Crack.
That's the point where I stopped trying to troubleshoot and decided to come to the forum and ask for help. Does anyone have any ideas as to what could be causing this sound? I can barely hear it at normal listening levels, and when music is on I can't hear it at all.
Any and all advice/help would be appreciated! For context, I'm using a JDSLabs ODAC, HD 650s, hand-made cables (I did the cable project to learn how to solder before doing the Crack. I have tested these on multiple devices and proven they work. I also used commercial cables to test the Crack), and have a JDSLabs O2 as my other amp.
Thank you!
Reply #1 on: February 11, 2013, 12:28:39 PM
Sounds like it may be interference from something like flourescent or LED lightbulbs, a light dimmer, electric motors and things like that.  Can you move the crack and dac to another room and try it there and see if the buzzing persists?
Offline Alonzo
Reply #2 on: February 11, 2013, 01:34:29 PM
To echo Jim,
Do you have a cordless phone or wireless router near the amp?  I picked up interference from my ASUS router when my Crack amp was on a shelf below it.
Alonzo
Reply #3 on: February 11, 2013, 05:23:54 PM
short the inputs and see if the buzz goes away.
Reply #4 on: February 11, 2013, 06:00:37 PM
Interestingly enough, I found out some new information. I moved everything into another room and used my laptop for the setup - no more buzzing. I moved it back to where it was, still plugged into my laptop - no buzzing. I swapped back to the USB cable to my desktop - buzzing. I then changed USB ports on my desktop and tried a different USB cable, but every feed from my desktop had the buzzing.
So basically, it's my desktop. I'm not sure what exactly could be causing this, though, or how to fix it. Any ideas?
Good news is that it's not my amp!!!
Reply #5 on: February 11, 2013, 06:10:38 PM
Check what else is connected to your desktop. When I charge my iPhone from my desktop it generates so much god awful buzzing/clicking garbage that I can't listen to the the desktop's audio thru headphones.
Offline Guy Boisvert
Reply #6 on: February 12, 2013, 12:49:08 AM
Make sure that the transformer screw that holds down the ground connection is tight [one of four on the top of the transformer]  . Give it a turn or so, and see what happens.
Reply #7 on: February 12, 2013, 03:33:08 AM
@Doc:
I only have mouse, keyboard, microphone, and DAC in my desktop. I tried unplugging each individually, but none made a difference. I noticed that the buzzing happens when Windows goes into its login screen - maybe it's one of my accessory hard drives? I'll try unplugging those later today.
Any other possible ideas?
I'll try tightening the screw later today, as well.
Reply #8 on: February 12, 2013, 04:23:29 AM
One thing that has also helped with this situation is to go through the computer and tighten every single bolt and nut you can find.  It's no guarantee, but it has worked for more people than you would ever think.
Also, try using one of the usb ports that are closest to the motherboard -- again sometimes the ports at the end of long ribbon cables can also pick up radiated noises inside the computer.
HTH,
Jim
Reply #9 on: February 12, 2013, 04:54:26 AM
If it goes noisy at a particular screen, maybe try turning off the monitor and see if the sound changes.
Reply #10 on: February 12, 2013, 12:31:00 PM
Ok, so I've tried:
  • Tightening all screws in the computer
  • Removing every cable from the computer individually and restarting each time while listening
  • Disconnecting my monitor on start
  • Moving the desktop while listening to the buzzing (it should change when I move it a foot or so if it's an interference issue, right?)
Unfortunately, a new problem arose. I left the amp on while I was at school today, came back, and now there is spontaneous popping/crackling on average once every 5 seconds. Also, the popping/crackling seems to be isolated to the right channel. I read in the manual that this could be a tube issue... is there any way I can test this?
« Last Edit: February 12, 2013, 12:32:45 PM by BaksideAttak »
Offline ice9mike
Reply #11 on: February 12, 2013, 01:32:37 PM
After I dropped the top plate of my crack I had the popping crackling sound in the left channel only. I could visually see this by watching the 6080 tube with the lights off. The popping and crackling were generated from arcing inside the tube. The tube also became very microphonic picking up the slightest movements and touches on the top plate.
ice9mike
Reply #12 on: February 12, 2013, 02:41:26 PM
I looked at the 6080 in the dark but didn't see any arcing. I am not sure how the tube could have been damaged, as it was sitting on my desk all day untouched when the popping started, and I'm unbelievably careful around the amp. And the popping is much, much louder than the buzzing (at normal listening levels), as it doesn't go away when the potentiometer is all the way down. I am considering buying replacement tubes, but I'd really like to be able to confirm that it's a tube issue before purchasing expensive tubes. Especially since I saved up for so long for the Crack - I don't really have the money for replacements! But now that I'm listening to my O2 again, everything sounds so hollow :( Spoiled already.
I can try and get a recording of the popping and the buzzing changing with the potentiometer if anyone sees any value to having those data.
Thanks for everyone's help!!!
Reply #13 on: February 12, 2013, 02:53:25 PM
It is possible that a tube that went noisy after it cooked in for a while. Another less likely possibility would be a poorly seated tube. You might try shutting the amp off, pulling and reseating the tubes in the sockets and running it again to see if that stopped the noise. Beyond that, the only easy way to see if a tube is making the noise is to try a different tube.
It is also possible for a tube to go through a noisy phase and then get quiet again. Or it may just stay noisy. Tubes are kinda like women that way.
Offline adamct
  • Maxxximum CAPacity Crack
Reply #14 on: February 12, 2013, 04:39:22 PM
And like men...
