Quickie preamp
underdawg · 10949
Offline Wanderer
Reply #15 on: February 22, 2013, 04:28:32 AM
I have been reading and I thought you either use the pcjj or the chokes, are you saying to add both to it one at time or either or?
One or the other. You can use chokes or PJCC mod, not both at once.
They both increase the gain but the PJCC sounded "smoother" to me.
Your Milage May Vary
Kevin R-M
Offline underdawg
Reply #16 on: February 22, 2013, 04:55:17 AM
ok thanks ill stay with the pcjj then
4krow
Reply #17 on: February 22, 2013, 06:55:27 AM
Ok, maybe I'm just lazy, but I don't remember seeing a price for the chokes. Would be a simpler install, not that pjjs is a problem.
4krow
Reply #18 on: February 22, 2013, 06:57:28 AM
pjccs     sooooory
Offline Wanderer
Reply #19 on: February 22, 2013, 08:05:34 AM
Thread on the chokes here:
http://www.bottlehead.com/smf/index.php/topic,70.0.html
You source the Hammond chokes from an outside supplier. Not expensive.
As I said I find the PJCCS better but others prefer the plate chokes. Worth a try.
Kevin R-M
Offline earwaxxer
Reply #20 on: February 22, 2013, 02:15:00 PM
Eric
Offline galyons
  • Geary Lyons
Reply #21 on: February 22, 2013, 03:26:01 PM
Batteries from radio shack industrial grade.
Now there is an oxymoron if I have ever seen one!!   ;)
Quickies are fun and perform to an amazing level!  Radio Shack...not so much!  ;D
Cheers,
Geary
Offline underdawg
Reply #22 on: February 22, 2013, 03:29:38 PM
I was just trying to find reasonable batteries is all, and at least the shack changes the stock frequently. :D
Reply #23 on: February 22, 2013, 06:59:39 PM
FYI - a 47uF-100uF at 6+V will work for the cathode bypass capacitors.
Offline underdawg
Reply #24 on: February 23, 2013, 02:12:28 AM
why such a high value capacitor, normally I bypass power supply caps with .1 to 1 uf caps?
Reply #25 on: February 23, 2013, 05:02:37 AM
A bypass capacitor implies that it's bypassing a larger capacitor.
The capacitor across the cathode resistor is there to act as a short for AC on the filament, removing degenerative feedback that would otherwise be there.
The cathode bypass cap also stabilizes the bias point, though this becomes unnecessary with the PJCSS upgrade IMO.
The size of the cathode bypass cap must be sufficient to offer the same "short" across all audio frequencies and then some.  The 1000uF cap we put in the last Quickie was used because we already had it, the new Quickie uses a 150uF capacitor that we added to our inventory for the BeePre.
Reply #26 on: February 23, 2013, 06:57:02 AM
The above post is an example of Bottlehead's business acumen.  Stocking a new part costs money.  Until it is necessary you don't do it.
« Last Edit: February 23, 2013, 10:23:18 AM by Grainger49 »
Offline underdawg
Reply #27 on: February 23, 2013, 01:24:36 PM
so based on 1000 uf and 150 uf, I assume since I just ordered one its coming with 150 uf caps, so I have some nice mundorf 390 electrolytics that should work ok?
Offline underdawg
Reply #28 on: February 23, 2013, 01:42:40 PM
The caps I have are bipolar 390ufd 63 volt, but I am not sure what side is the negative either, I feel stupid being in electronics 25 years and cant tell, tried to google but mundorfs site couldnt tell me.Anyone know if they will work and which side is the negative?
Reply #29 on: February 23, 2013, 02:12:25 PM
You mean there is no stripe on the Mundorf?
