Troubleshooting voltage issues
rockpassion · 8633
Offline rockpassion
on: February 21, 2013, 01:33:12 PM
I have finished my BeePre build and am checking the resistance and voltage.  All my resistance readings are looking good but some of the Voltage on the B side are out of tolerance.  All the tubes on both the A and B side are glowing.  The diodes on the A side are all glowing and the Voltage is within tolerance.  However, the B side is off and the diodes are not glowing.  Here are my readings;
Terminal                               Voltage (DC)              Should be
11                                           163.8                         146 +/- 1%
12                                           0                                 0
13                                           0                                 0
14                                           0                                 0
15                                           165.4                          186
16                                           5.1                               5
17                                           165.3                          90-110
18                                           0                                 0
19                                           9.89                            9.85
20                                           0                                  0
21                                           0                                  0
22                                           220.2                           213
23                                           0                                  0
24                                           0                                  0
25                                           219.9                           213
26                                           0                                  0
27                                           0                                  0
28                                           0                                  0
29                                           6.85                             6.8
30                                           6.86                             6.8
31                                           13.73                           13.6
32                                           0                                  0
33                                           0                                  0
34                                           14.11                           13.6
35                                           7.03                             6.8
36                                           7.04                             6.8
37                                           0                                  0
38                                           0                                  0
39                                           0                                  0
40                                           207.3                           213
41                                           0                                  0
42                                           0                                  0
43                                           206.8                           213
44                                           0                                  0
45                                           0                                  0
46                                           206.8                           213
B2                                           0                                  0
b3                                           164.4                           90-110
D3                                           4.98                             3.5-4.5
d7                                            162.4                          147
D9                                           162.2                           147
Thanks before hand for any help that can be given.
Richard
Richard Vince
VPI MkIV, Woody Tonearm w/Shelter 501 MkII Cart. w/Soundsmith rebuild, Cinemag CMQEE-3440A SUT, Eros Phono Preamp, Beepre Preamp , QuickSilver V4 Amps, DIY 89259 Speaker Cables  & interconnects, VH Audio Power Cables, OPPO 205 Player, DIY 3 way speakers
Online Doc B.
Reply #1 on: February 21, 2013, 02:06:40 PM
Looks to me like both the tube and the LED bias string are not conducting. So it could be a bad connection at the PC board under that 300B. You might want to make sure you have good connections at all solder pads, no miswires to the board and no solder bridges on the board, either top or bottom.  Might also be a bad LED, but eliminate other possibilities first.
Offline rockpassion
Reply #2 on: February 21, 2013, 06:43:44 PM
Doc I found the problem, you were right I had a wire out of place.  Fixed the problem and everything checked out.  I am listening right now and all that can say is wow!!!.  Clarity and depth to the sound stage, my system always had decent breadth to the sound stage but it was not real deep, it is now.  And the clarity is stunning.  I am listening to Cowboy Junkies Trinity session on CD and there is more detail than I have ever heard before.  Lastly, it is phenomenally musical.  With the balance I can dial it into fit the room much better than before.
I bought the sorbathane feet you recommended.  I will post the details of what I hear when I get them.
While the kit was the most complicated kit I have tried your instructions were fantastic.  The pictures really helped in some cases.  Good job to you and your crew.  To anyone building or wanting to build this kit just take your time and double check your work.  No matter how good the instructions are it is amazing how you either misread, misinterpret, or simply make a mistake so take it slow and you will definitely be rewarded.
Thanks again for the wonderful kit and product.  You have made my week.
Richard
Richard Vince
Online Doc B.
Reply #3 on: February 21, 2013, 06:46:31 PM
Alright! Good job of sorting! You just made the week of everyone involved in the project. Thank you!
Offline Jim R.
  • Blind Bottlehead
Reply #4 on: February 23, 2013, 06:02:57 AM
Hey Richard,
Congratulations on getting the first BeePree working!
I'm looking forward to hearing from the others that are putting them together right now as well.  Sounds like another off-the-charts winner from the BH gang!
-- Jim
Offline denti alligator
Reply #5 on: February 23, 2013, 09:33:31 AM
How about a picture?
- Sam
Offline KevO
Reply #6 on: February 24, 2013, 10:02:53 AM
Richard,
Great job! Thanks for posting the review. Your description of the BeePree sound is just what I hoped for.
You have motivated me to get soldering.
Mine is in the box still, but the bench is clean and ready to go.
Kevin
Offline rockpassion
Reply #7 on: February 24, 2013, 05:33:40 PM
Kevin,
I finished my Eros about a month ago and it was hooked into a Foreplay II.  I did not think it could get better.  Since last Thursday I have been listening to LP's.  The Eros/BeePre is pure magic; musical, detailed and a soundstage to die for. This combo really puts Cd's to shame.
So don't hesitate get going and I hope you find it as unbelievable as I do.
Richard
Richard Vince
