General Category
Tech Tools
Solder Diameter
Solder Diameter
mpent
3452
mpent
Full Member
Solder Diameter
March 08, 2013, 12:37:48 PM
Hello all,
I will soon be acquiring a Sex kit and am in the process of amassing the necessary tools for completion. Is there a preferred solder diameter that is best chosen for this type work?
Thank you.
Michael
Michael
Grainger49
Hero Member
Re: Solder Diameter
Reply #1 on:
March 08, 2013, 01:51:31 PM
It is often personal preference. I prefer small diameter solder. Since it is sold by weight, it wouldn't make much difference in price.
earwaxxer
Hero Member
Re: Solder Diameter
Reply #2 on:
March 08, 2013, 01:54:44 PM
I like the skinny stuff.
Eric
mpent
Full Member
Re: Solder Diameter
Reply #3 on:
March 08, 2013, 02:50:48 PM
Thanks. I will start with .31 diameter.
Michael
grufti
Sr. Member
Re: Solder Diameter
Reply #4 on:
March 09, 2013, 09:04:32 AM
I hope you mean .031". The other (.31) would be way too thick for electronic work.
mpent
Full Member
Re: Solder Diameter
Reply #5 on:
March 10, 2013, 10:26:58 AM
Yes, I meant .031. Thanks for clarifying though.
Michael
hibitec
Newbie
Re: Solder Diameter
Reply #6 on:
March 25, 2013, 10:14:55 PM
I have the Crack on order and also trying to amass my tools. What type of core flux do you recommend? No-clean, RA, or RMA?
I have also chosen to go with 63/37. Is this a good choice?
Grainger49
Hero Member
Re: Solder Diameter
Reply #7 on:
March 25, 2013, 11:54:45 PM
I prefer a small diameter solder. That allows putting as much or little solder on at a time as I want.
Good electronic solder has flux in it. Whatever type is in the solder you chose will be fine. I have never known what flux was in the solder I used.
It is my habit to clean the tip before and after every solder joint. This keeps the tip clean.
Good luck!
General Category
Tech Tools
Solder Diameter
