Which Way to Go???
BNAL · 6564
Reply #15 on: March 20, 2013, 11:29:15 AM
You can still get one. Four left...
Offline BNAL
Reply #16 on: March 20, 2013, 11:49:19 AM
If you through in a turntable I'll take one.   :D
Brad Nalitt
Iron Upgraded S.E.X. Amp 2.0
Foreplay III
Quickie w/PJCCS
Eros Phono
Offline xcortes
Reply #17 on: March 20, 2013, 11:49:28 AM
That directed to me ;)?
Xavier Cortes
Offline BNAL
Reply #18 on: March 20, 2013, 12:06:43 PM
Anyone willing to prove a free turntable. LOL I'm not picky.
On a serious note I'm trying to make strategic decisions based on my budget. Since I now have a pre-amp with a phono section I was thinking it would be a good opportunity to get back into vinyl.  Just having a hard time deciding on a table at my price range.
Brad Nalitt
Foreplay III
Quickie w/PJCCS
Eros Phono
Reply #19 on: March 20, 2013, 12:58:44 PM
Ok, I'll weigh in.  Older than Dan, a little younger than PJ.  I'm an old fart and it says so under my avatar.
Offline johnsonad
Reply #20 on: March 20, 2013, 02:48:38 PM
Brad,
Pick up an old Empire deck like Dan is using and enjoy refurbishing it. I've got TD-124 that needs a home but it's outside your budget.
Offline chard
Reply #21 on: March 20, 2013, 03:11:21 PM
$800 should be enough to get a good used turntable on ebay. I bought a Rega P5 turntable with the corresponding cartridge for $900. The cartridge itself sells for $795 new. The turntable I got was lightly used and works perfectly.
Clifford Hard
Reply #22 on: March 22, 2013, 12:04:49 AM
I would say buy a rebuilt Dual 1229 and use a nice cartridge.  Maybe a Denon 103.  You will need a SUT for it.  But I know that is a nice sounding combination.  The arm and cartridge are very well suited to each other.
Offline Chris
Reply #23 on: March 22, 2013, 12:31:58 PM
Yeah a Denon 103 is a great call...
Offline johnsonad
Reply #24 on: March 22, 2013, 12:57:10 PM
Just another opinion my friend, forget the Denon cart. Find a great MM cart with a removable stylus and even better one that can fit a JICO SAS profile.  I've had a Zu 103R, stock 103's, 103R's and a Soundsmith retipped 103R. It may work for some but not all people.
My $3500 Lyra Kleos cart sits in a box and the $250 JICO MM-1 with SAS stylus is in constant play and works great with the Eros and the Tube Phono.
The JICO SAS profile is amazing. I've used it on the MM-1, a few Empire carts, and the last Shure cart. The MM-1 fit my system best but the others were great.  With as many swap meet and freeby records I've collected even though they are cleaned with a VPI 16, plays per stylus is hard to beat with a good MM and JICO makes an outstanding stylus.
Just my two cents ;)
Offline BNAL
Reply #25 on: March 23, 2013, 08:06:44 AM
Aaron, Grainger,
I like the idea of getting an older turntable and fixing it up. I did a quick search and see there is information on fixing up Empire TTs. I'm going to do a little research on the Dual tables to see what's on the web.
Also, the information on a cartage is great.
Brad Nalitt
Foreplay III
Quickie w/PJCCS
Eros Phono
Reply #26 on: March 23, 2013, 11:17:51 AM
Brad,
There is a thread on Audio-Karma about restoring Empire tables:
http://www.audiokarma.org/forums/showthread.php?t=278075
