Soft start shunt update?
ssssly · 40525
Offline johnsonad
Reply #45 on: October 01, 2010, 10:39:35 AM
A bump for interested parties. Hopefully you guys are moved in and getting caught up :)
Reply #46 on: October 01, 2010, 10:45:45 AM
Still moving (a huge job with several unforseen delays), and still getting ready for RMAF. The soft start upgrade (along with the power cord kit we owe early Stereomour purchasers) is the #1 priority when we get back from RMAF.
Reply #47 on: November 03, 2010, 07:18:15 AM
PJ has sent the final revision of the new Paramount soft start PC board to me and we will be ordering some prototype boards to use for the manual photographs shortly. Hope to be ready to start taking orders in a week or two.
Offline johnsonad
Reply #48 on: November 03, 2010, 09:59:14 AM
Nice! Thanks Doc!
Offline johnsonad
Reply #49 on: December 04, 2010, 12:01:58 PM
Monthly bump.  I know you all are working hard over there :)
Reply #50 on: December 04, 2010, 01:51:12 PM
Waiting for the last resistor to show up in order to schedule the photo shoot. Seems to be taking forever.
Reply #51 on: December 15, 2010, 12:37:44 PM
OK, prototype is up and running nicely. Eileen is costing the parts today, and I have the assembly photos processed and ready to put into the manual. Hope to be able to take orders for the retrofit online in the next few days, and incorporate the new circuit into Paramount 1.1 in the next few weeks.
This mod is fairly extensive. It removes the existing PC board over the 12AT7 socket, the 12AT7, the nine pin socket and the terminal strips around the 9 pin socket. It will include a new, bigger and slightly more complex PC board with soft start function and the parts to stuff it, heatsinks for the active load power transistors, a new nine pin socket, new standoffs, mounting hardware and t-strips, a new beefier zener string and 5670 tube - all X 2, for the pair of monoblocks.
Do you need it in your Paramounts?
Here's what it does, to help you decide -
Firstly the new driver PC board has a soft start function. This delays the B+ to the plate of the driver tube for about 30 seconds at startup. I should note here that once fired up, the amp will need to sit for about 20 minutes after you turn it off for the circuit to "reset" itself and function with the soft start. This was added in response to a user who was using EML 2A3s in the direct coupled 2A3 version of Paramount and experiencing 2A3s arcing at startup when hit with that driver plate supply B+ before the filament could heat up. This new soft start circuit will resolve that issue. Off the top of my head we have not heard of anyone experiencing this arcing issue with anything other than the EML 2A3 and the long discontinued AVVT 2A3s. And this should not be an issue in the cap coupled 300B version. However the soft start may be useful in extending the lifetime of other tubes as well.
Secondly, the zener diode string has been beefed up. The original string worked fine unless you goofed something up in the build that overstressed it. The new string is much more tolerant of errant solder joints, miswires, etc. The circuit has been stress tested by me personally - 'nuff said.
The MJE5731As on the new PC board now sport heat sinks to extend their reliability as well.
One of the most noticeable changes is that we have gone to a 5670/2C51/WE396A tube as the driver. Why? Partly because a lot of folks found that the 12AT7 had to much gain in their system which led to hair trigger volume controls and a bit more transmission of the noise floor from front end equipment than they liked. The 5670 has a mu of 33 as opposed to the mu of 60 of the 12AT7. The 5670 is also a very sweet sounding, particularly linear tube, that we feel is step up sonically from the typical 12AT7. There's enough variety of brands to make tube rolling interesting and it is not prohibitively expensive. Even if you are running your Paramount in 300B mode like I do, you may find the 5670 the most compelling reason to upgrade your Paramounts to the new setup.
OK, the next thing you want to know is the price, right? We're gonna bite the bullet for a couple weeks and offer an introductory price of $199 for the retrofit kit. On January 1, 2011 the regular price of $249 will take effect. I'll get an order page up in the next day or two, or you can call Eileen today at 206-451-4275 to order.
I think at this point that we will be able to hold the price of the upcoming Paramount 1.1 kit that includes this upgrade to within $50 of the current price. We have some of the current version kit parts in stock, and as a little incentive to move them out we will offer six Paramount kits in the current 1.0 version (12AT7 driver, no soft start) for $100 off the regular price. That means you can get the current version of the Paramount 2A3 kit for $1349 and the current version of the Paramount 300B kit for $1399. That deal is only good until January 1st or until we sell all six kits, which ever comes first, and you will need to call Eileen at 206-451-4275 or email her at [email protected] to get this special price.
« Last Edit: December 15, 2010, 12:49:43 PM by Doc B. »
Offline xcortes
Reply #52 on: December 15, 2010, 01:18:35 PM
Quote
'Nough said. I'll order three pairs. Price is per pair, right?
I'm learning how to use FPE and my idea is to eventually move all my BH gear to Tube Repro-like chassises. What a good opportunity to change to the soft start shunts!
Xavier Cortes
Reply #53 on: December 15, 2010, 01:27:39 PM
Yes, price is for a kit to upgrade a pair of amps. We'll put your order at the top of the list. I should have the kit ready in a few days.
Offline Bryon
Reply #54 on: December 15, 2010, 03:30:37 PM
Great news - even though I do not own Paramounts [at least not yet], the update will work with my Paraglows, albeit with a few adjustments, yes?
If so, I'll order a kit as soon as they are available.  I've actually already ordered my first pair of 5670's to roll, it would be a shame if they didn't make it into an amp.
Bryon
Offline johnsonad
Reply #55 on: December 15, 2010, 11:32:55 PM
Me too!  One pair please.  You can put the kit in with my custom Eros when finished to save on shipping :)  I'll email Eileen also.
Offline RPMac
Reply #56 on: December 27, 2010, 08:45:13 AM
Bryon
Will these work for a Paraglow upgrade?
Reply #57 on: December 27, 2010, 08:52:55 AM
The kit could be made to work. We are not currently publishing step by step instructions for this, I am writing instructions specific to the original Paramount first. So for now at least one would have to do some figuring on their own to adapt it to other designs.
Offline RPMac
Reply #58 on: December 27, 2010, 09:42:40 AM
Can't learn any sooner...order on the way.
Offline ssssly
Reply #59 on: December 27, 2010, 09:58:00 AM
Doc
Maybe you or PJ could post a list of kits that this will work with. From my discussion with PJ about this I know for instance that this will not work for PMour 1s because the power transformer doesn't have the headroom. Could be isolated due to the older tranny design but folks my be more apt to adopt this if at least they knew if it can work with what they have. I know for myself, if I know something can work I am more likely to buy it and then figure it out.
