power LED
aragorn723 · 11078
Offline pushbroom
Reply #15 on: May 30, 2013, 01:56:14 PM
This might work too, but I have no experience with that particular switch.
when you say might what is your hesitation?  i'm very interested in making this mod work but it's def not worth a switch that costs half as much as the preamp lol
Josh
never satisfied, always improving
Offline adamct
  • Maxxximum CAPacity Crack
Reply #16 on: May 30, 2013, 03:14:36 PM
Switches are expensive. And anything beyond a SPST, DPST, SPDT or DPDT switch is doubly expensive. It's an unfortunate fact of life...
Reply #17 on: May 30, 2013, 05:25:06 PM
The hesitation would mostly be about noise and just switch quality in general.  If I really wanted something like this for myself, I'd end up buying the Goldpoint.
Offline galyons
  • Geary Lyons
Reply #18 on: May 30, 2013, 05:37:30 PM
Don't confuse cost and value.  The Quickie maybe inexpensive, but it plays way above it's price point as a kit.  I put a Goldpoint stepped attenuator in mine.  I consider it a good investment and it pays dividends daily!
Cheers,
Geary
4krow
Reply #19 on: May 30, 2013, 07:08:48 PM
Geary,
   I did the same thing for my Q. The GP just seemed to be the best choice given the role it plays.
  The idea of an LED as a power indicator is a good one, but so often in life, a simple idea isn't.
Offline adamct
Reply #20 on: June 07, 2013, 08:09:02 AM
Use a red one - they have the lowest voltage drop
It is probably just the luck of the draw and the specific LEDs used (which presumably aren't representative and therefore shouldn't be relied on), but see the empirical test results at the bottom of this page. The green and yellow LEDs both had lower voltage drops than the red.
Reply #21 on: June 07, 2013, 06:09:01 PM
Most important, is you need to find an LED that you can live with, not some semi Laser beam, that will turn you into an Ax murderer.
I once wired, one of the  nifty new high output blue LED's into my CD player.
terrible decision.
Offline adamct
Reply #22 on: June 10, 2013, 05:45:08 AM
So...I completed my Quickie build this weekend. It turned out VERY nicely, if I do say so myself.  ;D
The deviations from stock are as follows:
1. I mounted the batteries on the underside
2. Installed a "ladder-style" stepped attenuator,
3. Installed 2.2uf ClarityCap ESA caps on the outputs,
4. Replaced the 1,000uf electrolytic caps with 100uf ClarityCap SAs,
5. Installed "upgraded" RCA jacks, and
6. Installed a power LED.
I used this LED. It only draws 2mA, and the luminosity is 1.2 to 2.0 mcd, so it definitely isn't bright at all. The forward voltage drop is 1.9V.
Funnily enough, this might be one of those rare instances where a modification made it easier to identify a problem in the circuit, rather than harder. When I first put the Quickie together, I couldn't get it working. After running various tests, I decided to try Paul's patented "chopstick" test. I poked around at various places in the circuit, and the LED immediately went on when I poked one solder joint in particular. It make it a piece of cake to identify the issue (it turned out that when I soldered one of the wires, it was inserted too far into the terminal hole, so that the solder flowed around the insulation, rather than onto the wire itself - I didn't notice this immediately, because it was a relatively crowded terminal with other wires that were correctly soldered at the same hole).
I'm very glad I installed the LED. Recently I've forgotten to turn off my tube amps a couple of times. While that's not a catastrophe, it's not ideal. At least those amps were wall-powered. If I do that with the Quickie, I'll need to swap the batteries, and given my mods, that is a relatively painful process.
I'll post pictures once I've finished the base. I also have a PJCCS on the way...I'm just hoping my mods don't make that a pain to install...
Best regards,
Adam
4krow
Reply #23 on: June 10, 2013, 07:29:57 AM
Of course you realize that photos are required now. How can I brainstorm new ideas all by myself?
Offline adamct
Reply #24 on: June 10, 2013, 08:28:00 AM
LOL. I'll take pictures tonight. But you will have to excuse the unfinished base...
Adam
Offline adamct
Reply #25 on: June 10, 2013, 08:25:35 PM
Greg,
Pics posted here. Enjoy!
Best,
Adam
Reply #26 on: June 11, 2013, 07:31:06 PM
This is a pretty bizarre table with the voltages.  You can get a red LED with a forward voltage drop of 1.6V to 12V (easily, there may be other obscure special order choices), whereas yellow LED's range from 1.8V to 12V (hence you can get a red LED with the lowest drop).  The table is likely an amalgomation of random junk box LED's, where the actual forward voltage would be better determined by varying the current through the LED and creating a voltage vs. current curve to visualize the nominal drop.
