What 300b's are you running?
debk · 28172
Offline johnsonad
Reply #30 on: April 17, 2013, 05:16:16 PM
Thanks Deb!  I'm very tempted by those tubes.  Too bad we don't live closer together so I could listen to your stash!
When you get a chance, could you post the current draws for your different tubes?  It would be interesting to see what the KR tubes draw..
« Last Edit: April 17, 2013, 05:22:26 PM by johnsonad »
Offline debk
Reply #31 on: April 18, 2013, 02:42:02 AM
I have about 5 hours on the KR's now.  They have "opened" up more, very spacious and detailed sounding.  I am very happy I bought these, the best sounding 300b I have tried in the BeePre.
The data sheet that came with the tubes say the filament current is rated at  1.2A.  The actual test data included with the tubes are 1.11A and 1.12A.
I have not had a chance to make any measurements myself.  When I get a chance I will drag it down to Lab (Ok, Basement but Lab sounds better) and make some measurements
Deb
« Last Edit: April 18, 2013, 06:50:00 AM by debk »
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Offline johnsonad
Reply #32 on: April 18, 2013, 06:45:02 AM
Thanks Deb, though it raises more questions and concerns.
PJ, Deb's tubes are drawing less that normal WE spec current.  I called the TubeDepot and all of their tubes in stock draw 1.13 amps or less.  Thoughts??
Reply #33 on: April 18, 2013, 11:40:31 AM
... all of their tubes in stock draw 1.13 amps or less.  Thoughts??
So, they don't meet their spec, do they? But it's close. When I have more voltage data, I'll have some thoughts....
The voltage variation is about half the current variation, so 1.13amps is 6% low and the voltage would be 3% high, close enough. Do the numbers, and you'll see that 1.1 to 1.3 amps is a nominally safe range - if we ignore variations in component values and build resistances in individual amps. So I am looking to learn what the build variations may be, and what the tube variations may be, before making any recommendations.
Ignoring the other variations as above, you might think you could say that a 1.3A tube will work. But you can't say a tube model with 1.3A +/-0.5A current draw will work - half of them will draw too much current.
Offline debk
Reply #34 on: April 18, 2013, 11:49:39 AM
Without more data I wouldn't want to try the 1.3A EML.
Though the KR don't quite meet spec they sound very good.
I will try and get you voltage data next week.  My son is coming for a visit this weekend and I probably will not get to it till next week
Deb
Debra K
Eros 2Phono amp
Roon Nucleus
Jager speakers
Offline debk
Reply #35 on: April 18, 2013, 11:56:07 AM
One other observation about the KR tubes, they are much less microphonic than the Psvane are.
Deb
Debra K
Eros 2Phono amp
Roon Nucleus
Jager speakers
Offline johnsonad
Reply #36 on: June 01, 2013, 02:11:23 PM
I tried the TJ 300B mesh this weekend.  I enjoyed this tube in my Paramounts but it wasn't the best combo for my BeePre and speakers.  Too light weight, no body or soul.  I only gave them an hour or so but to my ears and system, the EH 300B Gold Grid have been the best sounding tube so far.
