Sex Amp - What version?
John EH · 2297
Offline John EH
on: May 16, 2013, 01:45:34 PM
I want to C4S my SEX amp but unsure if I need the 2.0 or 2.1 version.   How can I tell?
John
Reply #1 on: May 16, 2013, 01:51:41 PM
Iron is probably easiest: the 2.0 output transformer is a Speco that is mounted on top of the chassis with wires passing down either side through the plate. The 2.1 has a Bottlehead choke mounted on top (and a Bottlehead output transformer mounted below(PC-3 and OT-2, respective)). The wires for the choke pass through only one hole to get under the chassis. The 2.1 also has cooling vents on the chassis. If you're still not clear, post a pic.
Offline John EH
Reply #2 on: May 16, 2013, 02:05:34 PM
I'm 2.0 then.  Thanks.
John
Offline John EH
Reply #3 on: May 16, 2013, 02:14:28 PM
And just ordered the C4S upgrade kit.  Thanks again.
John
