Would it be possible to get a summary of the mods done so far? I'd be interested in a parts list as I have a Reduction on order. Guess I'll be reading that manual soon
... Can't wait.
The stock circuit has similar parts values to the Eros, but they are amalgamated differently.
0.01uF EQ cap (5% film and foil parts are supplied with the kit)
0.03uF EQ cap, which is three 0.01uF caps in parallel (again, 5% film and foil caps are supplied)
0.1uF coupling cap and 0.47uf coupling cap (more 5% film and foil caps, though the 5% tolerance isn't useful here)
I wouldn't recommend going out and buying boutique caps until you have the Reduction in-hand. While there is more space for different parts, there still isn't space for Teflon caps or anything along those lines, and the 0.47uF caps are best upgraded after the upgrade kit is retrofitted.
