Taking pre-orders!
Doc B. · 28471
on: May 17, 2013, 01:25:05 PM
We got all the final details worked out and we are now taking orders for an initial run of 25 Mainline kits at a special price. I'm really happy with this one, it's the first headphone amp that can pull me away from my reference system.
http://www.bottlehead.com/store.php/products/mainline-headphone-amplifier-kit
Reply #1 on: May 18, 2013, 04:32:57 PM
Woo Hoo! Thank you for the orders!
Offline dubiousmike
Reply #2 on: May 23, 2013, 10:00:56 AM
Just placed my mainline order.  So excited to be a part of the initial run!
Mike M.
Reply #3 on: May 23, 2013, 10:07:14 AM
Thank you! Orders are starting to pick up a little speed today. So if you are considering getting in on this pre-release price, ordering sooner will probably be safer than ordering later.
Offline Kai
Reply #4 on: May 23, 2013, 10:48:22 AM
Hey Doc, I ordered the mainline a couple days ago.
I built a smack before. Since it was the first amp i've ever built, i didn't care much about the "details", and this time..i wanted to pay a bit more attention to this amp...starting with the solder, was wondering if there's a specific type you would recommend. Silver?lead?
Thank you!
Kai
Offline HF9
  • Zynsonix.com
    • Zynsonix.com
Reply #5 on: May 25, 2013, 06:00:17 AM
Thank you!
I'm curious about Docs favorite solder too. Many people like the Kester 63/37, it's easy to work with and not too expensive. I personally like the Cardas solder, it's also easy to work with, has a low melting temperature, and contains a small amount of copper and silver. It's about 3x as expensive as the Kester though ;)
Reply #6 on: May 25, 2013, 06:28:25 AM
Kester is fine, and Cardas is really nice. Truth is I inherited a lifetime supply of various spools from Buddha when he passed away. So we kinda pick thru it when a spool runs low and grab anything that looks interesting. Most of it is 63/37, some is 2% Ag. One thing to be careful of is old solder. It gets kinda oxidized and funky, and can be difficult to work with.
Offline grufti
Reply #7 on: May 25, 2013, 07:50:06 AM
Just in case Kai is from somewhere in Europe: WBT-0805 and/or Mundorf MSOLS are two types of solder that work well. Melting point is right around 220C for both. I'm pretty sure you can find those with a search engine. I would expect something like 25 Euros for 50g or so.
Offline Kai
Reply #8 on: May 25, 2013, 01:48:25 PM
Thanks all for the information.
I have been considering the Cardas solder for the past couple of days. Would it be better to use solder with lead or lead-free. Would someone explain the differences please?
Thank you!
Reply #9 on: May 25, 2013, 01:50:11 PM
Solder with lead in it works, solder without lead doesn't.
Reply #10 on: May 25, 2013, 04:42:01 PM
I agree, lead free solder sucks...John
Offline Kai
Reply #11 on: May 25, 2013, 09:22:47 PM
Is it because lead free solder is more difficult to work with? or would it have an actual impact on the sound/performance?
Offline johnsonad
Reply #12 on: May 26, 2013, 03:31:14 AM
Difficult to work with.
Offline Spinifex
Reply #13 on: May 26, 2013, 04:46:53 AM
You win, preordered.  :D
Reply #14 on: May 26, 2013, 07:09:15 AM
Kai,
I used up a 60/40 pound roll of solder a few years back.  I've had it since the 70s.
I bought a pound roll of Cardas Eutectic solder which will be my lifetime supply.  I'm 63.  Will be bequeathed to poster Paully.
The key to solder joints is getting the solder to "freeze" solid.  The Eutectic solder is a mixture that freezes at the same temperature.  So both, or all, components go from liquid to solid at the same temperature.
This makes it harder to make a bad solder joint.
'nuff said?
