Finish on stock Bottlehead chassis
adamct · 11860
Offline caffeinator
Reply #15 on: June 15, 2013, 01:55:45 PM
Real brass-wire wheels are often used for cleaning steel things (like threads, tool parts, and such) while not taking off the base metal.  They cost way more than steel wire wheels, and tend not to last as long.  They would probably not work as well to grain aluminum plate as steel wire.  A lot of wheels sold as brass are actually brass-plated steel wire, which would work fine - no harm for the brass to be there and might keep the wheel from rusting (as if that's a concern).
Ditto Doc's cautions about doing that outside, not only because of inhalation issues, but aluminum dust can be an explosion hazard.  Though it seems unlikely for a small-scale job, it is still possible...as if you needed another reason to take it outside, I suppose.
Offline STURMJ
Reply #16 on: June 15, 2013, 05:23:01 PM
My take would be that brass, being much softer than steel, would be less aggressive than steel wires, ie for cleaning and not marring the base metal ( much). Since you are trying to mar the metal you want steel. As for brass plated... must be for anti corrosion, as stated before.
