Powdercoat; Stereomour- where to grind down to metal?
azrockitman · 2156
Offline azrockitman
I apologize.  I know I saw reference to this somewhere, perhaps even a reply to my post but I can't find it. I have both sides of my plate powder coated.  Can you confirm what locations need to be ground down to bare metal?  And do I need to ground to bare metal on top and bottom of the plate?
Tim
Esoteric DV-50, Technics SL1200-M3D, B&K Phono 10 Preamp, Sumiko Blue Point Special Evo III, Bottlehead Stereomour, Orca's
Reply #1 on: June 15, 2013, 07:21:28 PM
Hello Tim,
Ground the plate to bare metal on the bottom side of the chassis on the where terminal strip closest to the input selector switch mounts.
Ground the plate to bare metal on the bottom side of the chassis where the #8 screw passes through by the IEC power entry socket.
Ground the plate to bare metal where the terminal strip closest to the volume control mounts.
I don't think any other places need to be ground down.
Offline azrockitman
Reply #2 on: June 15, 2013, 07:57:47 PM
Perfect.  Just what I needed.  Thanks!
