Another batt question
jcastellano131514 · 8790
Offline jcastellano131514
on: June 16, 2013, 12:12:47 PM
Hi,
I have a quickie 1.1 for some time and I am very satisfied with it. A little time ago, I installed the PJCCS upgrade and I think maybe I have something wrong. I have checked the voltages and it seems ok. The problem is battery drain, I feel very sure that the batts drain faster with the PJCCS than without it. Or the quickie drains more batt if you gear up the volume? I am using a diy phono stage that needs to gear up the volume to get some nice sound. I have tried with a solid state preamp and I do not have to gear up the volume as up as withe the quickie. Can the gain of the quickie be increased?
Regards,
Jorge
Reply #1 on: June 16, 2013, 02:43:17 PM
Jorge,
The gain is set by the tube.  Any Phono stage I know of has two amplifying stages.  The Quickie has only one.  So it can't even be modified for use with a magnetic cartridge.
This has been asked before.  And if you search Quickie and phono you might find a much better explanation.
Reply #2 on: June 16, 2013, 03:18:19 PM
The batteries will drain a little bit more quickly with the PJCCS, as there is some biasing current in addition to the plate current.
Offline earwaxxer
Reply #3 on: July 14, 2013, 01:53:10 PM
I would go with rechargeables. Get much more play time and drive. Curious about what you think of the sound?
Eric
Offline wullymc
Reply #4 on: July 14, 2013, 04:01:29 PM
I have a Quickie 1.1 and find I go through the 9v in about 35 hours.  I have the PJCCS.
Eric brand of rechargeable are you using?  I am looking at getting some
Dave
Project RPM5.1 with 2M Bronze/Graham Slee Era Gold V/Quickie with PJCSS/Paramount 1.1 300B/Woden Valiant
ODAC/Crack/DT880 600ohm
Current Project:  Beepre!!!
Offline corndog71
Reply #5 on: July 14, 2013, 04:45:59 PM
Yep, with PJCCS the 9V's go quicker.  This was my solution and I don't regret it one bit.  ;D  It's been almost a year and I've only had to charge them once.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2FBottlehead%2520Quickie%2Faf3ade1f.jpg&hash=5a18e46b55a9a0bdb22c20b5e0e2cac2c799e433)
Rob
Offline earwaxxer
Reply #6 on: July 14, 2013, 05:49:06 PM
Yep, lead acids are one way to go.
The other is with NiMH. You can get 37V in a number of different ways. You can combine in series a shit load of AA 1.2V into packs - you can buy AA battery holders at Radio Shack that hold 8 AA each. Four of those, wire the packs in series and you are set. I went with 5 7.2V 3000mah packs that are used in RC cars. with 12V SLAB's (sealed lead acid battery) you only need 3. Like Rob said, they last for quite a while. While you are at it, you can use AA rechargeables for the heater batteries. One you get comfortable with using rechargeables, dont be surprised if you start using batteries for some of your other kit (ex. wall wart power supplies). Of course you have to get a decent charger. Its worth it though.
Eric
Reply #7 on: July 14, 2013, 07:57:43 PM
They should last a good bit longer than that. Are the fresh? Are they really alkalines? There are still a lot of carbon-zinc batteries around, sold as "long life" or "heavy duty" - apparently because they aren't either one.
Buy from a place that has a lot of turnover. From the specs, an alkaline in perfect condition should last around 200 hours. Most people seem to get more like 120 hours, presumably because the batteries have suffered in storage or in transit - excessive heat, for too long, kills them.
The PJCCS should cut the life something like 15%-20%, no more.
« Last Edit: July 14, 2013, 08:02:37 PM by Paul Joppa »
Offline wullymc
Reply #8 on: July 14, 2013, 11:35:52 PM
Thanks Paul for the feedback.
That is funny because they were brand new Duracell alkaline batteries.  I have since replaced them with Energizer alkaline.
I came to the 35hour mark by counting sides of albums.  20 minutes per side.  Maybe it is a little more than 35 hours considering there are the batteries for testing the build but I definitely didn't get 100 hours out of them.
I will chalk up these batteries to transit/storage/heat times and hope for better with the Energizer.
Dave
« Last Edit: July 14, 2013, 11:48:46 PM by wullymc »
Dave
Offline precd
Reply #9 on: January 09, 2014, 12:44:49 PM
What are the specs on your SLABs?
Adcom GFA-545
Bottlehead Quickie Preamp
Elac Debut B6
Marantz CD5004
JRiver Software
Audioquest Dragonfly
Offline corndog71
Reply #10 on: January 09, 2014, 02:07:41 PM
They are Power Sonic 12V 5AHr SLA.  I bought them on Amazon for about $18ea plus shipping.
Rob
Offline precd
Reply #11 on: January 09, 2014, 02:24:32 PM
Great! What charger are you using?
Adcom GFA-545
Elac Debut B6
Marantz CD5004
JRiver Software
Offline corndog71
Reply #12 on: January 09, 2014, 05:10:45 PM
CTEK US 800 12V charger
Rob
Offline aragorn723
Reply #13 on: January 10, 2014, 10:16:28 AM
Are Sunbeam heavy duty batteries carbon-zinc?
Offline Wanderer
Reply #14 on: January 10, 2014, 04:39:33 PM
I have used the Sunbeams - cheapies from the Dollar Store, yes?
They work but don't expect long life. I suspect they are carbon zinc but don't know. Sounded fine while they lasted but did not record how long they held up. I have not done the math on how long they last versus cost.
Kevin R-M
