S.E.X. 2.0 iron upgrade kit now available
Doc B. · 22332
Reply #30 on: July 23, 2013, 01:10:29 PM
Ok, now on to the plate chokes... will these new plate chokes work as ps chokes in the paramour -- 2a3 or 45, and would they be an upgrade over the triad c7x?  Gears are turning.
The C7-X has 10H of inductance, the upgrade iron has 20 or 40H, depending on the tap used, so I would use the C7-X for power supply duty.
Reply #31 on: July 24, 2013, 06:23:36 PM
The plate chokes are 2 or 3 times the resistance of the C7-X, so they drop more voltage. And they are designed to handle the output tube plate current. Of course they handle some AC current as well, so they can handle a bit more DC as long as the AC is small (i.e. not in a choke-input filter). At first glance the temperature rise looks OK.
Reply #32 on: July 26, 2013, 06:26:26 AM
Thanks, Paul, just an idea and I really didn't know the Rdc specs for the various chokes except the c7x, which every bottlehead probably knows is 270 ohms ;-).
Another opt question: is there a way to configure the opt for an 8 ohm load with a primary closer to 5k, instead of 4 or 8?  I knew there are some intermediate taps in there somewhere but no idea what they are.  I'm seriously thinking of putting this opt in the sr-45 as the nickel with the 45 tube seems to be just a bit too sweet.
Reply #33 on: August 06, 2013, 11:42:53 AM
You can get 5K:16 (roughly) but nothing else.
Reply #34 on: August 06, 2013, 02:47:04 PM
Thanks Paul, but after thinking about it a bit I decided that I really didn't want to back myself into the 16 ohm speaker category.
