S.E.X. 2.0 iron upgrade kit now available
Doc B. · 22288
Offline fullheadofnothing
Reply #15 on: June 21, 2013, 02:56:20 PM
#6. Because we're nice people, we will be including fresh fiber washers, since a lot of them will be crushed after sitting under pressure for years on the upgrade amp. We can toss anything else you might need into your box. Email your requests to replacementparts <at> bottlehead <dot> com and I'll make sure you are set.
Reply #16 on: June 21, 2013, 08:26:11 PM
The iron should have #6 hardware.  For an extra dollar or two, you could undoubtedly talk Eileen into sending you some fiber washers and solder tabs.
Offline Natural Sound
Reply #17 on: June 28, 2013, 04:53:12 AM
Any estimates as to when these transformers will be ready for shipping?
Reply #18 on: June 28, 2013, 06:02:07 AM
 Early next week barring  unforeseen delays.
Reply #19 on: June 28, 2013, 07:08:46 AM
Awesome, thanks.
Offline Jim R.
  • Blind Bottlehead
Reply #20 on: July 01, 2013, 05:46:33 AM
So, it is looking that one will still have to configure the new iron as an autoformer -- is this a correct assumption?  If so, I'm also guessing that balanced mode would not be possible with that configuration.
-- Jim
Reply #21 on: July 01, 2013, 06:36:01 AM
That is correct, it remains an autoformer configuration.
Reply #22 on: July 13, 2013, 02:53:06 PM
Will the instructions be posted online or something? My kit didn't come with any.
Reply #23 on: July 13, 2013, 02:53:58 PM
There is indeed a manual for the kit.  If you PM me your e-mail address, I'll send you a link so you can download it.
Reply #24 on: July 14, 2013, 06:35:01 AM
Paul,
I got the manual, thanks. I have a couple more questions if you don
Reply #25 on: July 14, 2013, 06:51:36 AM
Yes, blue and red for the #45, with heatshrink over the black wire.
As far as the impedance goes, you will want to use the OT-2 transformer, but not quite as-wired in the SEX.  The SEX amp uses the transformer to provide an ~8K reflected load to the plate of the output triode, while the Paramour wants to see 4K.
Consequently, for something like an 8 Ohm Orca, you can wire the OT-3 transformer for 16 Ohms to reflect the correct load.
Reply #26 on: July 14, 2013, 09:15:15 AM
Got it, thanks!
Offline Jim R.
  • Blind Bottlehead
Reply #27 on: July 23, 2013, 05:39:12 AM
Along the same lines as Tom's questions -- can the opt be configured for 4k primary and 16 ohm secondary?
Jim
Reply #28 on: July 23, 2013, 06:56:05 AM
Yes.
Offline Jim R.
  • Blind Bottlehead
Reply #29 on: July 23, 2013, 12:55:04 PM
Ok, now on to the plate chokes... will these new plate chokes work as ps chokes in the paramour -- 2a3 or 45, and would they be an upgrade over the triad c7x?  Gears are turning.
-- Jim
