Bottlehead Kits
Legacy Kit Products
Quickie
B1 Buffer install
B1 Buffer install
RobsterD
1173
RobsterD
Newbie
B1 Buffer install
June 20, 2013, 10:25:58 AM
Hi
Built a Quickie and have a B1 buffer that I have kicking around,so I'm going to mount it in the amp as a separate output in parallel to the existing output.
Where would be best to connect after the o/p caps or before ?
Cheers
Rob
RobsterD
Newbie
Re: B1 Buffer install
Reply #1 on:
July 05, 2013, 12:03:02 PM
Paul Birkeland
Global Moderator
Hero Member
Reply #2 on:
July 05, 2013, 12:30:49 PM
If you connect before the coupling caps, the plate voltage of the tubes will be present at that connection.
A fair amount of this will be shunted to ground when you plug it into the B1, and you'll probably draw an arc or get a spark.
Bottlehead Kits
Legacy Kit Products
Quickie
B1 Buffer install
