Thanks for reading
I have spent a few evenings of sheer enjoyment putting together the crack. The resistance and voltage checks were a bit of a let down. When I tested resistance with terminal 12 as the ground I got nutty figures, with the excepts of the tests for terminals 13, 14 & 20. On the other hand, when I used terminal 11 as the ground, I got resistance measurements that were in the ballpark.
Fast forward to the voltage test. Both tubes glowed fine and the fuse didn't blow. Started testing and got readings of 236 for terminals 1, 2, 3, 4 and 5. Stopped at this point as something was obviously up the creek.
What have I done wrong?
To make matters worse, I melted a 220 uF cap in the process of trying to trouble shoot and wrecked a 270K resister in trying to get it off.
Help!
