46 drain wires through THAT little hole??
azrockitman · 2397
Offline azrockitman
on: June 27, 2013, 04:22:15 PM
Ok, I exaggerate, but I'm trying to complete the wiring for the volume pot, and I have two drain wires left to wire and I'll be damned if I can get even the first of the two in the hole.  Can I alternatively:
Use the upper point?  (8U)
or
Wrap the two drain wires around another drain wire that IS in the hole and make sure to solder that connection before leaving that area?
Esoteric DV-50, Technics SL1200-M3D, B&K Phono 10 Preamp, Sumiko Blue Point Special Evo III, Bottlehead Stereomour, Orca's
Offline Sh7eleven
Reply #1 on: June 27, 2013, 05:21:55 PM
Based on a few of your other posts, I assume you're talking about the stereomour you're building and are referring to the drain wires at terminal 8.  I had the same issue - I was advised to wrap the last few drain wires around the bundle and solder them. It successfully worked for me. Check out this thread I had going in the stereomour forum:
http://www.bottlehead.com/smf/index.php/topic,4355.msg40488.html#msg40488
Sean Hamill
music, ski, music
Stereomour
Crack
FPIII extended
Offline azrockitman
Reply #2 on: June 27, 2013, 06:00:45 PM
Thanks for the reply and the link, Sh7eleven.  Now I can move on as well.  Thanks again
Offline Sh7eleven
Reply #3 on: June 27, 2013, 06:24:42 PM
no worries - you're getting close to the promised land!
Sean Hamill
music, ski, music
Stereomour
Crack
FPIII extended
Reply #4 on: June 27, 2013, 07:09:09 PM
I'll just mention that this issue has been mitigate in newer kits by using a different cable for input wiring with one drain wire per four twisted pairs (and the drain wire is teensy).
Good luck with the build, it sounds like you're really, really close!
