Quickie 1.1 Voltage Issue [solved]
wullymc · 6683
Reply #15 on: July 07, 2013, 11:56:07 PM
Dave,
You almost certainly have a loose/marginal solder joint.  You should put it up for a few days.  Clear your head and come back refreshed.  Too often we get to a point where we can't see the forest for the trees.
When you come back touch up all the power supply solder joints and try the chop stick test.
Reply #16 on: July 08, 2013, 12:28:26 PM
Another possibility is a wire that is broken under the insulation, probably when it was stripped. You should be able to pull gently but firmly on each wire but check the solder joints first...John
Offline wullymc
Reply #17 on: July 11, 2013, 10:59:48 AM
Hey guys,
Went back to the Quickie today.
I noticed that one of the ground connections solder wasn't a good one.  Resoldered that joint and all the input rca jacks.
Test voltages...ok.
I tried it and I am getting sound.  The right channel comes in and out.  I tried tapping the Selector switch on the button.  This seems to affect it.  Also, when I adjust the volume the right channel goes.  Tapping on the selector button brings back the right channel.
Seems to me I should now look at the solder connections between the selector and the right input on the attenuator....slowly getting there!
Thanks for your suggestions and help!...Dave
Dave
Project RPM5.1 with 2M Bronze/Graham Slee Era Gold V/Quickie with PJCSS/Paramount 1.1 300B/Woden Valiant
ODAC/Crack/DT880 600ohm
Current Project:  Beepre!!!
Offline wullymc
Reply #18 on: July 11, 2013, 04:14:53 PM
Thanks everyone for your help
I was able to getting the quickie working.  The final piece was a blotched solder joint at the selector switch.  Resoldered and I was off to the races.
Thanks again.  I think that is it for my Quickie..next stop upgrading my crack
Dave
4krow
Reply #19 on: July 11, 2013, 05:28:46 PM
  Many years ago, i had a trouble ticket for a lawyer. Tkt said No dial tone on any lines, any phones. It was summer, and when I asked the beautiful secretary where the phone system was mounted, 'it's right behind my desk', said she. Then I asked, what happened to the extension cord for this little system. "I used it for my desk fan." Case closed. Pun intended.
Offline earwaxxer
Reply #20 on: July 12, 2013, 04:32:56 PM
So, did ya fuck her?
Eric
4krow
Reply #21 on: July 12, 2013, 05:58:30 PM
In a manner of speaking, yes. I billed her $85. You can use yer imagination if ya want.
