Wrong resistance readings BeePre [Solved]
docbob52 · 5948
Offline docbob52
on: July 17, 2013, 01:41:08 PM
I got some incorrect resistance readings on my BeePre.
Supposed to be:        Actual reading:
T35 *                       .675M
T36 *                       .66M
T40 100k+               0 ohms
T41  0                       260 ohms
T43 100K+              0 ohms
T44  0 ohms            infinity (open circuit)
I checked my wiring before installation of the PC boards but I know that something must be wrong.  All help appreciated.
« Last Edit: July 22, 2013, 05:21:19 PM by Caucasian Blackplate »
Garrard 301/ high mass plinth, SME 312S tonearm/ Sleeping beauty cartridge/ Denon AU 320SUT. Transcendent audio GG preamp and OTL SOB power amp. Blumenstein Orca/Dungeness Speakers
Second system.  BH Paramount 300B amps.  BeePre.  Sony SCD777ES, Wyred4 sound Dac. Mac mini.
Reply #1 on: July 17, 2013, 06:06:15 PM
T40 being 0 Ohms means perhaps you have a black wire connecting there when there should be a red?
I think the 260 Ohms that you're seeing may be the 300 Ohm resistor in the high voltage supply.
There is 100% a miswire here, feel free to pop off the PC board above this power supply to snap a pic and post it here if you're unable to find the miswire.
Offline docbob52
Reply #2 on: July 18, 2013, 01:01:33 PM
Tnx so much PB. What is the easiest way to post a picture on the forum. Sorry I am a newbie to forums.
Offline adamct
  • Maxxximum CAPacity Crack
Reply #3 on: July 18, 2013, 03:24:55 PM
You have to upload the picture on a different site (e.g., Flickr), and then use the image post button to insert a link to the picture.
Best regards,
Adam
Reply #4 on: July 18, 2013, 04:17:24 PM
Best regards,
Adam
Actually you don't - with the current forum software (and unlike the old days), click on "Attachments and other options" and browse for the image file. Easy!
Reply #5 on: July 19, 2013, 12:11:01 AM
Bob,
Look in my corner (first page of the forum), then look at the FAQ Thread.  I show two ways of posting pictures.
Good luck!
« Last Edit: April 01, 2014, 03:01:46 AM by Grainger49 »
Offline docbob52
Reply #6 on: July 21, 2013, 01:27:20 PM
Still haven't found the mis-wire.  Also noted T15 was 300 ohms and should be low rising to 20K ohms.  Pictures are attached:
PB, thanks for your help.
Reply #7 on: July 21, 2013, 06:02:20 PM
Two things:
Are 42/41 connected?  The black wire should have a long stripped lead that binds these terminals together, I can't see it on your build.
What is the DC resistance between terminals 41 and 40?
(Thanks for taking the pictures, that's super helpful!)
Offline STURMJ
Reply #8 on: July 21, 2013, 07:28:25 PM
That's what I saw too. I just assumed that it must be there and I couldn't see it.
Offline docbob52
Reply #9 on: July 22, 2013, 12:03:47 PM
Yes, 42 and 41 are connected to the black wire which is stripped.  You can't see that in the picture as it is wired on the inside.
The resistance between 41 and 40 is 270k.
Reply #10 on: July 22, 2013, 12:16:09 PM
If 41 and 42 are connected and grounded, you can't have 260 Ohms on 42 and 0 Ohms on 42.  Can you recheck that?
Offline docbob52
Reply #11 on: July 22, 2013, 12:48:39 PM
TaDa!  You found it.  I rechecked and 42 was bound to 43 with the black wire and not 42-41.  I will blame this on tired old 61yo eyes. but it is really my fault.  Thank you both for helping me.
Robert Howard, Troy, Al.
Offline docbob52
Reply #12 on: July 22, 2013, 01:36:51 PM
All resistance check are spot on now.  Thank you so very much PB and SturmJ.  Bottlehead's support and products rule.
Reply #13 on: July 22, 2013, 05:19:29 PM
I'm glad we could help :)
Let us know how those voltages go.
