Non parafeed Paramount
xcortes · 9342
Offline xcortes
Reply #15 on: August 13, 2013, 07:38:41 PM
Paul, I promise that this will be my last how to modify anything questions for 20013.
If I want to do the said conversion to the 300B version of a Paramount or a Parabee, would the changes be the same.
AND, for what current would you recommend that the transformer be gapped?
Thanks a lot!
Xavier
« Last Edit: August 15, 2013, 05:32:36 PM by xcortes »
Xavier Cortes
Offline adamct
  • Maxxximum CAPacity Crack
Reply #16 on: August 13, 2013, 07:47:38 PM
Sure, Xavier. And I promise I won't make any inane posts on this forum in 20014.
 ;D
Reply #17 on: August 13, 2013, 07:50:03 PM
If I want to do the said conversion to the 300B version of a Paramount, would the changes be the same.
Are you planning on FS-030's or TFA-204's?
Offline xcortes
Reply #18 on: August 14, 2013, 02:08:34 AM
Ds025s all silver. Mike is building me a pair with all silver windings and 4 ohm secondaries which normally don't appear in the silver version.
Originally I was planning to build a Baby Ongaku. Later I decided to try a 300B BO (Ongaku Jr?). But it looks like the SR45 project will leave me with three spare pairs of Paramounts so probably I can just rebuild one. And I also have two pairs of ironless Parabee to rebuild so.....
My last request to Mike was to gap it for 70mA following a PJs post on the MQ forum where he auggested:
"2) You can ask Mike to make some DS-025s that are gapped for more current. You will lose some inductance and hence some deep bass, but otherwise it would retain the Baby-O basic character. Gapped for 70mA and operated at 300v at 60mA, which is a well documented 300B operating point, with very nearly the same cathode resistor - less than 2% different. You might get 7 watts. Full power DC current is 74mA, so DC overload will be similar to the Baby-O"
http://db.audioasylum.com/mhtml/m.html?forum=magnequest&n=10634&highlight=300b+baby&r=&search_url=%2Fcgi%2Fsearch.mpl%3F
« Last Edit: August 15, 2013, 05:33:59 PM by xcortes »
Xavier Cortes
Offline xcortes
Reply #19 on: August 15, 2013, 05:43:49 PM
OK Paul, since you're about to go for vacation I'll make it a single question and no more for the year :)
I'd like to replace the TFA 2004 and exo 03 in a Parabee with a ds025 gapped for 70mA. I like the idea you mentioned before of doing ultrapath: replacing the last electrolytic in the ps with a nice one and going to the cathode instead of to ground. So the big question is: what size a cap would be correct here?
Thanks !
Xavier Cortes
Reply #20 on: August 15, 2013, 05:58:47 PM
The usual recommendation comes from Thorsten (used to be pretty active on the DIYtube and SET boards). If the capacitive voltage divider ultrapath/cathode bypass matches the gain of the output stage, then any noise on the power supply is cancelled by cathode injection. Hard to be exact unless you are driving a constant-impedance speaker like a Magnepan, but roughly a gain of 3 so the ultrapath is 1/2 the cathode bypass. This assumes both are large - let's say, 25uF/50uF minimum for full frequency range.
Note that this does not affect the driver sensitivity to power sully noises - a C4S will solve that, but I wanted to mention it. With a c4S's driver, this is kind of a poor-man's shunt regulator.  :^)
I'll be back by the D
Offline xcortes
Reply #21 on: August 15, 2013, 06:17:42 PM
Awesome. Thanks a lot! I will be using the driver section from the original Paramounts that I saved when I went soft start so its sr and c4s.
Enjoy your vacation.
Xavier
Xavier Cortes
