Build question
odamone · 6167
Reply #15 on: August 08, 2013, 06:00:26 AM
If you have the output transformer wired for 32 ohms, some more sensitive headphones will pickup a little hum. You can fix that by reconfiguring the output transformer to 16 or even 8 ohms without any real sonic penalty.
Offline odamone
Reply #16 on: August 09, 2013, 03:12:59 PM
Thanks for the tip. I have the AKG K702 and the Beyerdynamic DT770 PRO 250ohm version. I assume the latter isn't sensitive, but both of these suckers require nearly no volume.
I also noticed that the left channel comes in first / louder than the right as the volume is turned up slowly from zero. I don't detect a misbalance at listening volume. Is that normal?
CD -> FLAC -> Squeezebox Touch -> Rega DAC -> PrimaLuna Dialogue Premium Integrated Amplifier -> Quad 22L2
Oliver
Offline adamct
  • Maxxximum CAPacity Crack
Reply #17 on: August 09, 2013, 04:46:46 PM
Yes. Almost all stereo potentiometers have channel imbalance at low volumes. True, some are better than others, but it is pretty much inherent in the way they are constructed. But at normal volume levels it should be fine. If you frequently find yourself listening at low volume levels, you can install resistors on the inputs or use signal attenuators, which will let you listen at a hire volume level.
Or...you can install a $25 stepped attenuator, since stepped attenuators don't have channel imbalance issues.
Offline odamone
Reply #18 on: August 09, 2013, 06:10:25 PM
Thanks! I love this forum. I have lots to learn, thanks for helping.
Oliver
Offline adamct
Reply #19 on: August 09, 2013, 06:12:43 PM
LOL...."hire volume level"...
[forehead slap]  ::)
Offline odamone
Reply #20 on: August 09, 2013, 06:26:59 PM
Ha, I totally missed that.
Oliver
