Vacuum tube rectifier
vetmed · 5109
Reply #15 on: October 10, 2013, 04:39:14 AM
Could be. Could also be a way to get a 5v supply if you only have a 6.3v winding -- use one parallel set in both lines.
Reply #16 on: October 10, 2013, 04:59:21 AM
That makes more sense than what I suggested!
Offline vetmed
Reply #17 on: October 10, 2013, 11:32:47 AM
The only HV diodes I have on hand are some 1N5062s which have a forward voltage drop of about 1.1 volts at their rated 2A. Maybe use 4, 2 in parallel  back to back with another 2 in parallel? Should half the current demand on the diodes resulting in less forward drop :-\
Robert Lees
Robert Lees
Offline vetmed
Reply #18 on: October 19, 2013, 04:56:13 PM
FWIW I installed two 0.1 ohm resistors in series and the voltage is now 5.1 volts, good enough for government work ;) The B+ dropped a whopping 3 volts ;D Happy that the rectifier tube will last longer :)
Regards
   Robert Lees
Robert Lees
