Choking my amps...
ALL212 · 2510
Offline ALL212
on: October 27, 2013, 04:01:00 PM
There are many reads on putting in a choke.  What do they do for me?  ???
Aaron Luebke
Offline Lar
Reply #1 on: October 27, 2013, 04:59:55 PM
Lower the noise floor.
Larry V
Offline Paully
Reply #2 on: October 28, 2013, 04:18:59 AM
Do they lower ripple, make the sound smoother?  When I put the CX-7 in my Pramounts, smooth was my feeling.  Both Grainger and I heard a noticeable improvement.
Offline Daikini
Reply #3 on: October 28, 2013, 04:50:15 AM
Chokes as opposed to resistors in the power supply do result in less ripple, but for me that's not the main attraction. Power supplies on bottlehead gear are plenty quiet as designed. With chokes, you can use lower value caps to get the same smoothing, which makes putting a film cap in the last position feasible. Just about any film cap will have lower ESR than the best electrolytics, and that's where I think much of the sonic benefit comes from.
David Gray
Empire 208/Jelco 750d/Nagaoka mp300 -> Seduction -> Stereomour ->Klipsch Heresy IIs w/ dual Polk PSW10s
Sony CDP-CX235 -> Schiit OptiModi -> Sex 2.1 -> Madisound BK-12m/Hifiman HE400
Offline RayP
Reply #4 on: October 29, 2013, 04:28:52 PM
You might find it interesting to play with a utility called PSUD that many builders use to design their power supplies. There is a learning curve to become proficient in its use but it is quite easy to play around to get an idea of what a choke will do for you.
http://www.duncanamps.com/psud2/
In addition if you search the Audio Asylum http://www.audioasylum.com/forums/tubediy/bbs.html there are differing opinions on how big a choke you need in terms of Henries and how much current they should carry. Search on LSES or flywheel and read but please do not mention the subject on that forum. The conversations became very heated. However it is useful to see how PSUD was used by some of the posters to illustrate their findings.
ray
Ray Perry
Reply #5 on: October 29, 2013, 04:43:48 PM
Just an FYI - LSES will not provide a sufficiently low noise floor for many of our products - especially the Crack, Reduction, and SEX.
