Confusion on speedball final voltage check at headphone jack
keithpgdrb · 2995
Offline keithpgdrb
Finished my speedball upgrade, checked all the voltages and they seem fine.  went to the last step of checking the voltage at the headphone plug tip.  instructions say that it shouldn't go past 9V.  I swear mine is going to like 20+volts.  its only for a split second, but its going there.  how can this be when everything else checks out ok?  To show what I'm seeing, I've included a video of me turning on the crack with the probes in place.  also, here are my voltage readings, just in case I've gotten it wrong.  Help!!!
Video, that hopefully works.
Voltage checks:
1. 87
2. 173
3. 0.8mv
4. 173
5. 89
6. 0
7. 110
8. 0
9. 109
10. 0
11. 0
12. 0
13. 172
14. 0
15. 192
16-
17-
18-
19. 80!!!! ok
20. 0
21. 210
A1. 88.6
A2. 0
A3. 1.53
A4. 0
A5. 0
A6. 86
A7. 0
A8. 1.5
A9. 0.9
B1  86
B2  172
B3  110
B4  88
B5  172
B6  109
B7  0
B8  0
Offline Chris65
Reply #1 on: November 03, 2013, 10:50:39 PM
I think you're fine, if everything else checks out. With Speedball the mV reading tends to be higher on the TRS jack check.
Or just do the mod: http://www.bottlehead.com/smf/index.php/topic,2946.0.html
Offline keithpgdrb
Reply #2 on: November 04, 2013, 03:57:33 AM
I was going to do that modification anyway.  that would solve my spike problem then?
Reply #3 on: November 04, 2013, 04:58:17 AM
It's OK. Those numbers aren't what really the headphones see. A 300 ohm headphone's impedance will lower the voltage by about a factor of 10.
Offline keithpgdrb
Reply #4 on: November 04, 2013, 05:28:57 AM
So I can start listening to TUNES!!??!!  Sweet!  Thank you Doc.
Reply #5 on: November 04, 2013, 08:30:32 AM
Yeah, and if you are still concerned just turn the amp on first without headphones plugged in, wait a few seconds, then plug headphones in.
Offline keithpgdrb
Reply #6 on: November 04, 2013, 09:20:23 AM
As long as you thnk the numbers are ok, I won't worry. Gonna add a few of your mods anyway n the week.  Looking forward to the tunes.
