lack of highs
charger · 4358
Offline charger
on: November 11, 2013, 04:17:15 AM
I hear a lack of highs in my system, i am considering if it's becouse coupling caps i placed , two 2,2 uf Munforf Supreme bypassed by two 0,22 uf Mundof Supreme , may be that the bypass cap is  not necessary ?
thank you
Oppo 980H - PC - Arcam rDac- Bottlehead Quickie- Abletec ALC040 - Signal cables Atlas Element Integra-speakers cables Tellerium Q black-Martin Logan Motion 15
Reply #1 on: November 11, 2013, 04:21:00 AM
The Mundorf caps I have in my system have good clean highs.  But you need to break in film caps.
How many hours have they played music?  Film need at least 4 days of music passing through them.
Offline corndog71
Reply #2 on: November 11, 2013, 04:57:11 AM
thank you
Try taking out the bypass caps and letting the bigger caps break in some more.
Rob
Offline charger
Reply #3 on: November 11, 2013, 05:22:30 AM
it's two weeks now i have placed them , and heard music a couple of hours a day so it' s 30 hours or so , now four days are 96 hours
Offline charger
Reply #4 on: November 11, 2013, 05:46:27 AM
also I found that damping too much tubes it reproduces a damped sound
Reply #5 on: November 11, 2013, 02:32:39 PM
I suggest you put your CD player in repeat and burn in the Quickie.  The amp doesn't need to be on, it just needs the load of the amp's input.
Offline charger
Reply #6 on: December 03, 2013, 01:25:25 AM
I can't understand, yesterday sound was really bright, dynamic , powerfull, today it is slow , darkish , what happens ? is it that capacitors are still breaking in ?
Reply #7 on: December 03, 2013, 05:25:02 AM
You might check your batteries' charge.
Offline charger
Reply #8 on: December 03, 2013, 05:53:32 AM
oh ok !!
Offline charger
Reply #9 on: December 04, 2013, 07:14:28 AM
under which voltage is better to change batteries ?
Offline danielehn
Reply #10 on: February 04, 2015, 09:57:15 AM
I don't know if it's just mine, but using rechargeable D-Cells reduces the sound quality noticeable since they are usually 1.2V and not 1.5V
Somewhere around 1.35 the sound quality have dropped  to a noticeable lvl
Reply #11 on: February 04, 2015, 02:34:14 PM
I've seen a wide variety of specifications and claims for dry-battery filament tube voltage. Most commercial-use tubes for battery radios (like the 3S4) are performance-specified at 1.4 volts, but most hearing-aid tubes, powered by the same kind of batteries, are specified at 1.25 volts. In fact, some mil-spec versions of regular radio tubes call for 1.25v +/- 0.25v - they are the same tube, only the spec has changed.
In the very earliest days, a rheostat was used to adjust dry-battery tubes to 1.1v, it was periodically adjusted to maintain the voltage as the battery ran down. (This is the origin of the 5-v tube too, with a rheostat and a 6-volt lead-acid battery.) In one RCA manual, the recommended range was 1.25-1.4 volts with a nominal 1.3 volts; an absolute maximum of 1.6 volts was called out.
