Hum problem with new built Stereomour [solved]
Kmmm · 13049
Offline jimiclow
Reply #30 on: November 19, 2013, 06:34:25 PM
Hi Jimiclow
What was your hum reading before you lowered the plate dissipation?
How sensitive are the speakers you have?
IIRC, I think it's only 0.2-0.3mv higher.  I forgot to mention that I also lowered the 45 filaments to 2.39 volts. Plate was dissipating 11.25watts before mod.
I have a quad of 97db Hoyt bedfords 8" full range.
« Last Edit: November 19, 2013, 06:38:11 PM by jimiclow »
SEX 2.1- Alps, Mundorf
Stock Crack
Schiit Asgard, Schiit Lyr
Technics SL1200mkII
Woo WA-6
Offline Kmmm
Reply #31 on: November 19, 2013, 06:41:45 PM
Yes, using the 4 ohm tap is a good idea.
At the moment the amp is wired for 16 ohm speakers
The AER's are 16 ohm. Should I use the 4 ohm taps?
Kaare
« Last Edit: November 19, 2013, 07:58:21 PM by Kmmm »
Kaare Mongstad
Reply #32 on: November 19, 2013, 11:24:45 PM
The rule of thumb is to use the one that sounds best.  The differences between the taps will not matter with 109dBW speakers.  Try 4 ohms and see if the hum diminishes.  If so then try the 8 ohm tap too.  See which sounds best to you.
Reply #33 on: November 20, 2013, 07:59:45 AM
Oh heck yeah! The big disadvantage will be a loss of output power (at 108dB sensitivity, this is unimportant).
Offline Kmmm
Reply #34 on: November 20, 2013, 09:39:05 AM
WOW!
Just wiered it for 4 ohm and guess what!
We are down to 1,2mV hum on the 2a3 ;D
That I can totally live with!
Thank you so much for your time, all of you;)
Cheers
Kaare
Kaare Mongstad
