S.E.X buzzing
greyhamster · 39067
Reply #45 on: January 20, 2014, 07:02:39 AM
Sorry for the confusion, there are two thread in this thread and I do get them mixed up.
Can you quantify "loud"? Like, by measuring the AC voltage at the speaker terminals? I understand that not everyone has a meter that will read a millivolt or less - I'm just trying to guess what candidate problems to look for.  If your meter will do this, it could help.
If you have some clip leads (cheap 10-pack at Radio Shack; very handy!) you can clip the power section grid (pin 1) to ground. If it still hums the same amount, it's in the power section, if not then it's coming into the driver section. The 450v caps are the respective filter caps to look at - 47uF for the power section and 22uF for the driver. Check for orientation, possible bulging, and good solder joints.
Offline J. Mauro
Reply #46 on: January 20, 2014, 08:31:40 AM
From the left channel terminal I am getting 144 mV and the right channel terminal I am getting 5 mV. This seems high so I may have done it incorrectly. Black lead on black terminal and red lead on red terminal? Once it warmed up it went to 39 mV and 6.6 mV respectively. This is so discouraging. Thanks again.
Jeremy Mauro
So long, and thanks for all the fish.
Reply #47 on: January 20, 2014, 09:23:11 AM
Guys, I am still having this problem. It is a loud buzzing sound more in the left channel than the right but the volume doesn't change with the volume control.
This is likely a loose solder joint in the power supply, probably around the 22uF capacitor on the left channel.
Offline J. Mauro
Reply #48 on: January 25, 2014, 02:07:03 PM
Ok, I am still at it but the problem seems to have shifted slightly. Now when I power it up there is a faint hum. After a few seconds it starts to get louder until it gets just as loud as it was before but now the sound is approximately equal in both channels with headphones. Without the headphones plugged in, I measure 6.6 mV on the left channel and 5.4 mV on the right. I have gone through and resoldered every terminal that looks less than perfect, especially those around the power supply capacitors and it is still buzzing. Please give me more suggestions. Tell me what else I can do. I am dying to hear this thing playing music. Thanks again in advance.
Jeremy Mauro
Reply #49 on: January 25, 2014, 03:20:12 PM
OK then, back to my previous suggestion to ground the grid of the power section of the tubes and see how much noise is left.
In addition, you have used the terms "hum" and "buzz" in this thread. Hum means it's a nearly pure low frequency tone, usually 120Hz - not deep bass but unquestionably in the bass. "Buzz" means the tone has a lot of harmonics and a raspy nature; what we used to call buzz-saw back when there were such things. This is a useful diagnostic - power supplies with some filtering but not enough will give a hum, while capacitive coupling such as heater to cathode coupling is biased towards the higher harmonics and has more of a buzz character. Can you sort out what you are hearing?
Offline J. Mauro
Reply #50 on: January 26, 2014, 06:09:59 AM
Ok, first things first. I did not have clip leads so I temporarily soldered in some hookup wire from each of the tubes pin 1 to ground. With that in place, it is virtually silent, only the faintest of hums. So I removed the temporary leads and resoldered the 22uf cap terminals as well as every other spot around the tubes sockets. I then put the tubes back in and tried it. Same sound, same volume, 5.4 mV left and 6.6 mV right which is what I meant to put in my previous post. Anyway, I tried a second set of tubes and the sound was still there, but lower at 3.7 mV left and 3.8 mV right. Then I tried the tubes that came with the kit, coin base Sylvanias and the sound went to 6.3 mV left and 3.7 mV right. As to the sound, it sounds to me as if it is a buzzing sound, not a hum. There are definitely variations in the harmonics. At this point, I think the tubes may be playing a role since the noise has changed in volume with each set of tubes.
Also, the tubes that measure 3.7 mV really are fairly quiet and loud sound could be due to the sensitive headphones I have 105 db at 44 Ohm Shure SRH440 for testing anyway. It worries me though because I have Denon D5000 headphones and Klipsch Heresy 1.5 speakers and I don't want that sound to color my listening. What is normal hum/buzz with the SEX? Will it decrease significantly with the C4S upgrade which I have yet to install? Thanks again.
Jeremy Mauro
Reply #51 on: January 26, 2014, 10:39:52 AM
THIS POST HAS BEEN MODIFIED TO CORRECT AN ERROR IN THE SECOND PARAGRAPH!!
Great data! That really helps; it's not the high voltage power supply (except possibly the last stage with the 22uF capacitor) and it's not the power stage. So it's coming in at the first stage. And it's buzzy, so there is probably a capacitive coupling going on. And it's in both channels - it's always possible, but very unlikely, that there is the identical fault in both channels.
My best guess at this point is that the 6.3v winding, which is common to both channels, is not properly grounded. You can check the DC resistance from power transformer terminal 10 (the 6v winding centertap) to the chassis. It's in the middle of page 22 in the manual. I'd check the resistance from the G terminal of the IEC inlet to the chassis as well, since it's right there. In both cases, check the transformer or socket terminal to the actual chassis, which tests all the mechanical and soldered connections. Check the resistance from power transformer terminal 10 to power transformer terminals 1 and 2 4 and 5, to be certain that terminal 10 is connected internally in the correct way - I'm trying to cover all the bases here!
If that does not make a difference, then it's back to that 22uF capacitor. The lead that attaches to 12U is grounded by the wire from 12L to 13L, and 13 is bolted to the chassis as the single point connection of signal ground to chassis ground. So check the resistance of that capacitor lead to the chassis itself.
11L and 11U are presumably good connections since the high voltage power does get to the tube, and you are certain about 11U. The only way this could fail is if at 11L the two resistors are connected but the joint to the lug itself has failed. You can check the resistance from the positive lead of the 22uF to either resistor (8.2K to T6 or 150K to A5).
« Last Edit: February 03, 2014, 05:48:52 PM by Paul Joppa »
Offline J. Mauro
Reply #52 on: January 27, 2014, 03:08:10 AM
Paul, thank you so much for the help. I checked the resistances around terminal 11 and the 22 uf cap and all checked out. I resoldered the ground connection from terminal 10 on the power transformer to the terminal strip 3. However, I do not know what the different resistances within the power transformer should be so I couldn't check that yet. Can you clarify that second paragraph for me? And can you clarify what an acceptable level of hum is for the SeX without C4S? Thanks again.
Jeremy Mauro
Offline J. Mauro
Reply #53 on: January 29, 2014, 11:55:04 AM
Paul and others, thank you very much for your help so far. I am however still in the thick of it. I am hoping to get that clarification about what those resistances should be around the PT-7 as well as a good explanation and a picture of the 120 Ohm resistors on the headphone jack. I would love to know some more details about why one would want them, whether they will be ok if I use speakers more than headphones, and exactly how to install them. Thanks again.
Jeremy Mauro
Reply #54 on: January 29, 2014, 01:17:03 PM
THIS POST HAS BEEN MODIFIED TO CORRECT AN ERROR IN NOTE 4)!!
Normal noise for a SEX amp is 0.3mV at the speaker terminals.
Second paragraph:
1) My best guess at this point is that the 6.3v winding, which is common to both channels, is not properly grounded. You can check the DC resistance from power transformer terminal 10 (the 6v winding centertap) to the chassis. It's in the middle of page 22 in the manual.
--- Properly grounded means zero resistance between terminal 10 of the power transformer and the chassis plate. See note number three below. No transformer resistance is involved. Note that you will not be able to measure with precision fractions of an ohm.
2) I'd check the resistance from the G terminal of the IEC inlet to the chassis as well, since it's right there.
--- Sorry, on the current IEC the terminal is labelled E (for Earth) rather than G (for Ground). My bad, I didn't look it up. There are three terminals on the IEC socket, labelled E, L, and N (for Earth, Line, and Neutral). There is a wire from terminal E to the chassis ground lug, as described on page 20 of the manual. check the resistance between the terminal E and the  chassis; it should be zero. See note number three below. No transformer resistance is involved. Note that you will not be able to measure with precision fractions of an ohm.
3)  In both cases, check the transformer or socket terminal to the actual chassis, which tests all the mechanical and soldered connections.
--- Do not re-solder. Do not connect the meter to the solder. Do not connect the meter to the wire. Connect one meter probe to the actual terminal itself. Connect the other meter probe to the chassis plate.
4) Check the resistance from power transformer terminal 10 to power transformer terminals 1 and 2 4 and 5, to be certain that terminal 10 is connected internally in the correct way - I'm trying to cover all the bases here!
--- The actual transformer resistance of this winding is too small to measure. Meters that can distinguish such small resistances from zero cost $2000 and up. So just look for as close to zero ohms as you can measure!   Note that you will not be able to measure with precision fractions of an ohm.
Clear now?
« Last Edit: February 03, 2014, 05:50:51 PM by Paul Joppa »
Offline J. Mauro
Reply #55 on: January 29, 2014, 01:36:02 PM
Yes, thank you very much Paul. That clarifies things nicely for me. I will check that later tonight and report back with my findings. Thanks again.
Jeremy Mauro
Offline J. Mauro
Reply #56 on: January 30, 2014, 04:18:28 PM
Ok, I finally got those new measurements done. The resistance between terminal 10 and the chassis plate started at 0.1 Ohms and climbed up to 1.3 Ohm before dropping down and hovering between 0.4 and 0.9 Ohms. When I checked again after a couple minutes it hovered between 0.3 and 0.7 Ohms.
The E terminal on the IEC resistance to the chassis plate hovered between 0.2 and 0.5 Ohms. Finally, the resistance between terminal 1 and 10, 2 and 10 on the PT did not even register on my meter, just showed O.L. I am assuming that the fluctuating resistances are a bad thing but I don't know why. Is it a bad connection? Solder joint? PT? Thanks again for the help.
« Last Edit: January 30, 2014, 04:41:56 PM by J. Mauro »
Jeremy Mauro
Reply #57 on: January 30, 2014, 05:15:46 PM
THIS POST WAS BASED ON AN ERROR OF MINE AND IS CANCELLED!! See later apology.
Bingo!  I think, anyhow. Looks like the terminal 10 is not connected to the center tap of the 6.3v winding.
First off, all resistances less than 1 ohm are probably zero, it's just hard to get an accurate measurement. Those are probably not the problem.
You can fake a good grounding, or ask Eileen (email the spare parts address) fora replacement transformer.
If you fake the grounding, it will confirm this to be the problem, so it might be interesting whether or not you ask for a replacement transformer. The easy way is to connect T1 (or T2, your choice) to T10 of the power transformer. Leave the connection of T10 to the chassis.
A better way is to use two 47 ohm resistors, T1 to T10 and T2 to T10. But the easy way will at least answer the question definitively, and will probably be good enough that no further effort is needed.
I should note two things:
1) If the easy way causes the fuse to blow, then your measurements of T1 to T10 and T2 to T10 were incorrect and we're back to Square Zero.
2) If either method works and gives low hum (finally!!) then you deserve a new power transformer if you want it.
If you can get a good high resolution close-up photo of the transformer T10, showing any internal transformer wires, that would be informative for us - but no sweat if that's not easy to do.
« Last Edit: February 03, 2014, 05:52:36 PM by Paul Joppa »
Reply #58 on: January 30, 2014, 05:19:24 PM
I would also mention that it's possible that you accidentally snipped off the wires that connect to T10 on the power transformer.  If this is the case, you can reconnect them with some solder.
Offline J. Mauro
Reply #59 on: January 30, 2014, 05:27:43 PM
Ok, I will try to get a good shot to show T10 to you guys. I am reasonably certain I did not snip those wires but I will definitely check. Barring that, I will try the 47 Ohm resistor way tomorrow and see what I come up with. Thanks a lot gentlemen. Have a great night.
Jeremy Mauro
