Yes.
Thanks.. At terminal 1, i get 40 M ohms (only sometimes, does that mean it's a cold solder joint, or is that ok?
terminal 6 says 0.. Did I do something wrong?
Here are the final measurements, the ones in bold i'm not sure about. Is it safe to move to voltage checks?
1,6 0 ohms , 0 ohms
2,7 0 ohms , 0 ohms
3,8 0 ohms , 0 ohms
4,9 1.073K , 1.074 K
5,10 0.5 ohm , 0.5 ohmRotary
1,4 92.8k, 101.5k2,3,5,6 0 ohms , 0 ohms, 0 ohms , 0 ohms
7,10 0 ohms , 0 ohms
8,9,10,11,12 1.079K, 1.079K, 1.078K, 1.078K
Potentiometer
A side top 0.5 ohm, bottom 0.5 ohmCenter top 2.1ohm , 2.2ohm
B side top 101.4K
bottom 92.7K
Dave
