Balanced output
mbbarton · 4875
Offline mbbarton
on: November 21, 2013, 12:29:17 AM
Is it possible to use two 3pin balanced outputs instead of 6.5mm stereo and 4 pin balanced? I have a nice cardas cable for LCD3 with twin 3pin balanced plugs
Reply #1 on: November 21, 2013, 01:17:39 AM
Personally i would put a 4pin XLR plug onto your headphone cable, or make up a small 4pin to dual 3pin adapter cable.   Fitting dual 3pins to the amp is of course an option if you really wanted to.
Reply #2 on: November 21, 2013, 05:16:26 AM
That is we we use the standard D style jacks. You can put whatever you like in the mounting holes, and a pair of XLRs could be installed using the wires that normally go to the 4 pin XLR.
