Blown Tube [solved]
squirreldude · 6972
Offline squirreldude
Reply #15 on: December 15, 2013, 01:38:52 PM
Thanks guys, I think we got it. I really didn't want to reheat all of my joints but that's what it took to get rid of the static. I've been listening for almost an hour now and haven't heard it again yet... fingers are crossed hoping it doesn't come back.
I hope the Speedball gives me less trouble now that I've learned better soldering techniques :)
Reply #16 on: January 26, 2014, 01:37:45 PM
Unfortunately, I have returned to the crack forum with the same problem as before. Since my last post, I have installed the speedball upgrade, received my replacement 6080 power tube from BH support, and had been functioning well for quite some time. Just today, I started hearing the scratching vinyl sound again. It actually blends in quite well with the distorted, electronic music I listen to. I cannot reproduce the problem, but noticed that when it does happen, the sound is affected by tapping or pushing on the top plate. I hadn't actually tried the replacement power tube up to this point, so I thought I'd roll it in just to see what happens. This tube blew just like the first one. I have popped two 6080 power tubes from BH now, but my new Winged "C" 6AS7G has been working fine for weeks.
I am totally at a loss. I'm pretty sure it's in the power circuit somewhere and it seems like I should check and reheat all my joints. However, I have tried this a couple of times with no success. Now that the speedball is in there, it will be even more of a PITA... Any ideas, or should I send this to someone and have it checked out?
Reply #17 on: January 26, 2014, 02:13:53 PM
You can use our repair service and we can look it over for you.
"Blowing" a 6080 tube is pretty tough.  They are incredibly rugged beasts that will take quite a beating.   It is very odd that the Russian 6AS7G works properly and the others do not.
Reply #18 on: January 26, 2014, 02:27:28 PM
Well, let me be more specific and perhaps reiterate my original post. I plugged in the power tube, flipped the on switch, and it slowly lit up for 10 or 20 seconds with no apparent issues. Then, the tube sparked with bright white/blue light and made an audible pop. It's not as dramatic a light bulb bursting, but it's certainly more than just warming up. As I said, it has happened the same way with two different tubes.
Who should I contact for repairs? I am working full time and taking graduate classes for the next few months, so I really don't have the time [or desire] to troubleshoot this further.
Reply #19 on: January 26, 2014, 02:34:33 PM
Repair services are available here.
Also, I just noticed the added black wires on the 6-lug terminal strips.  I'd recommend cutting those off.
Reply #20 on: January 31, 2014, 01:52:57 PM
Hey, Paul, can I have you clarify what is considered "stock configuration" as far as repairs go? Obviously some of the capacitor pr0n elsewhere in the forum would be exempt, but can I leave the speedball upgrade installed? I have one resistor attached to each RCA jack as well. Would these need to come out?
I hope to redo my voltage and resistances tomorrow after removing those added black wires on the terminal strips. I can't imagine that's the culprit, but it's worth a shot.
Reply #21 on: January 31, 2014, 03:48:36 PM
Yeah, cap porn gets pulled out.  Chokes get pulled out, etc.  The Speedball is still considered "Stock".
You're creating a shorted winding through part of the stack.  This is actually kind of a horrible thing to do to a power transformer.  (Like running your car on jet fuel)
Reply #22 on: February 01, 2014, 05:56:34 AM
Yikes! Well if it's analogous to running your car on jet fuel, it could explain why I keep getting sparks in the power tube. I pulled out the two wires connecting the ends of the terminal strips and did resistance/voltage checks. Everything looks the same as before; still up to spec. The only difference is that terminals 11, 17, and 22 are no longer part of the ground path. They do not give a resistance reading. Thus far, I haven't heard the dreadful noises either   ;D. I'll give it a week or two of listening and see if it shows up sometime.
I've been thinking about why the "shorted winding" problem might not have appeared in the voltage checks I did before. Perhaps you can correct my understanding of tube amps and power transformers. My guess is that the voltage going into the tube was higher than it should have been, but my 6AS7G was working overtime to properly control the outgoing voltages. In contrast, the unusually high voltage was too much for the 6080s and they failed. I wonder why the voltages weren't too high upstream of the tube though. I'd be interested to hear some reasoning from the experts.
Finally, do you think these 6080 tubes are toast? If they are as "incredibly rugged" as you say, is there a chance they could still function?
Voltages
1      78.2
2      180.8
3      0
4      179.2
5      78.9
6      0
7      110.3
8      0
9      107.7
10     0
11     0
12     0
13     180.8
14     0
15     198.8
20     0
21     218
A1     78.4
A2     0
A3     1.5
A4     0
A5     0
A6     77.1
A7     0
A8     1.5
A9     0
B1     77.0
B2     178.5
B3     109.7
B4     78.3
B5     178.2
B6     107.4
B7     0
B8     0
Reply #23 on: February 01, 2014, 12:42:50 PM
It looks like you now have a working amplifier.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fsound.westhost.com%2Fxfmr11-3.gif&hash=c494640faf5c41b7d98bd18d5628bd04424597cb)
If you trace the paths made by your black wires, screws, and transformer cover, you'll discover that they make loops through the transformer stack.
Reply #24 on: February 28, 2014, 09:31:37 AM
Just an update to this thread:
This Crack came in for repair, and we found that a little too much solder led to several cold solder joints, whose intermittent connections were causing this issue.
Reply #25 on: February 28, 2014, 09:38:15 AM
To further this, often the solution to cold joints is not to add more solder but to pay close attention when you reheat what is already there. Make sure that the solder flows over both parts being soldered together and has a smooth and shiny finish with fillets (i.e. the solder draws into the space between the parts) instead of lumps. If you see a thin line or little blobs of rosin around the edge of the solder joint it might also be in between the wire and the solder, creating a cold joint. A little more heat will help it to reliquify and get the solder in direct contact with the metal.
