Soft start kit alternate tubes
johnsonad · 14999
Offline johnsonad
on: December 25, 2013, 05:39:15 AM
I wasn't sure where to post this and technical topics seems a good fit.
I'm open to the idea of an alternate driver tube in my 300B amps which use the soft start board. Their operating point is; 350v, -75v, 50mA, 5k.  I looked back though some old posts and saw the 6sn7 mentioned though I'm assuming it would need to be a 6sn7gt or gta due to the plate voltage. In my current set up (100dB sensitive speakers) this would work but I'm planning on using a pair of 95dB sensitive speakers and will need a little higher amplification factor I'm assuming (BeePre as the preamp)? Ideally I wouldn't have to change the board or if so, minimally and I understand that the socket would need changed or in the least rewired.
Given this, can anyone suggest an alternate tube to try? Would a 6072 (12ay7) be an option (amplification factor of 40)?
Aaron
Reply #1 on: December 25, 2013, 05:47:28 AM
I'd suggest rolling back to the 12AT7.  Since you aren't directly coupled, you can remove the 300K plate load, 33K/10,000uF paralleled combination, and run the v1.0 driver circuit.
Offline johnsonad
Reply #2 on: December 25, 2013, 07:21:08 AM
Thanks Paul. I have a stash of 12at7's from the v1 and that's an easy conversion.  I don't need extra gain but don't want to loose what I have at the moment.  Did you guys have luck with any others tubes when deciding on the 5670?
Reply #3 on: December 25, 2013, 07:53:30 AM
It'd be easy enough to leave it as-is until you got your new speakers.  (Do you have 6dB of extra clicks on your BeeQuiet?)
Offline johnsonad
Reply #4 on: December 25, 2013, 07:59:54 AM
I do. I'm about 18dB down on CD and phono and around 9dB down on tape with the 100dB sensitive speakers.   Ideally I wouldn't mind trying a 6sn7 or a 6cg7 but I'm not in a hurry.  Gain isn't the primary focus, but trying the tone of a different driver tube at some point.
Reply #5 on: December 25, 2013, 09:02:26 AM
You'll lose 6 dB with your speaker change.  If you go from a 5670 to a 6CG7, you'll lose another 6 dB of gain, and you'll need to bias the cathode of the driver stage up pretty high so you can drive it with significant voltage from your preamp.
If you're willing to depart from 9 pin dual triodes and drill some extra holes in your Paramounts, there are some other options.
Offline johnsonad
Reply #6 on: December 25, 2013, 09:30:32 AM
I'm on a 12x18" chassis plate and have plenty of room for alternate tubes. I would even be open to two tubes, one for the shunt and the other as a driver. The base hole is already large enough for an octal. What did you have in mind?
Reply #7 on: December 25, 2013, 09:40:44 AM
You could try a 6688 triode wired, 6C45 (careful with plate voltage), 6GK5, 12GN7 triode wired, etc.
For my "utility" Paramounts, I used the 7 pin 6J6 as my regulator tube.  These are inexpensive, draw pretty light heater current, and it's easy enough to use one or both triodes depending on how much regulator current you can afford.
Do note that I think a pentode wired 3S4 (feed the screen from the 300B cathode) would drive the 300B pretty nicely.  This would have the added complication of rectifying the 6V winding and regulating it to 1.5V or 3V, but you would have the reward of an all DHT amp.  (I did this recently with a loctal pentode recently)
Offline johnsonad
Reply #8 on: December 25, 2013, 10:38:33 AM
The 6J6 sounds easy enough and I have access to hundreds of them.
Tell me more about the use of the 3S4 please. Have you tried it in this configuration yet? Would it be direct coupled or capacitor coupled? This is a fairly microphonic tube as a triode, would that improve at all wired as a pentode?  Would the filament need the same attention as the 300B gets or could I drive it from a battery pack as is done in the Quickie?
Reply #9 on: December 25, 2013, 10:52:11 AM
You could use a battery.
You get max transconductance with 1.5V on the filament.  You'd have 75V on the screen (more than max, but not by too much), and I'd run the tube at 100V.  With a 25K plate load, this should leave you with about the same gain as the 5670.  I'd run 6mA through the tube, and use a 25K/2W resistor from plate to ground (4mA), for a total of 10mA.  (90 Ohm R1)
You'll need to adjust the bias trim pot to see 7-8V on the filament so that you can get 100V on the plate of the 3S4 (I believe the "bottom" of the filament, see the datasheet), so the 4.99K resistor by the 10K trim pot should get another 4.99K resistor soldered across it to increase adjustment a bit.
Obviously, you'll need to increase the overall driver stage current to allow some current to flow through the shunt regulator.  If we assume 10mA through the 3S4 and its plate load, 1mA to bias it, then maybe add 2mA for the 6J6, which leaves you at ~13ma, so a 66 Ohm R1 or thereabouts resistor will work (a little extra current can be sunk through half the 6J6 without any concern).
If you want to make 3V for the 3S4, cut the drain wire going to the "CT" on the 6.3V feed.  Bridge rectify that into a 10,000uF/10V cap, then feed a 3.3V TO-220 regulator with a nice 10uF cap on the output.  (3.3V is kinda high, but the battery tubes are tolerant to voltage shifts).
Offline johnsonad
Reply #10 on: December 25, 2013, 11:22:24 AM
Thank you very much for the detailed reply Paul. It seems like a very doable conversion (3S4). Is 100v enough to swing the 300B (for my own understanding)? Are there any other DHT that I might want to consider?
I'm going to exhaust my stash of 2C51's and 5670's before changing driver tubes. So far with the tubes I'm using there seems to be room for improvement.  It could be the iron and amps as a whole breaking in too and I've got plenty of time to give them.
Reply #11 on: December 25, 2013, 01:21:45 PM
It could also be that particular 300B operating point, it'd be easy to tell if you had stock Paramounts to compare them to.
At 100VP on the 3S4, you will be in the ballpark to drive the 300B to clipping with your operating point.
Offline johnsonad
Reply #12 on: December 25, 2013, 04:09:26 PM
Good point but so far I'm really impressed by this sound. It does need to work out a few bugs but overall the range seems balanced and the bass is impressive. It really shows the difference in driver tubes, more so than what I remember with my original Paramounts. Maybe a few more years of experience has taught me better what to listen for.  I'm a little surprised at how much of a difference in sound the driver tube makes in this build. I've got about every brand made and am slowly working though them until we find one that meets the overall goal, then we can fine tune after that.
If it doesn't end up working out then I'll consider a different driver tube or an alternate operating point.
Reply #13 on: December 25, 2013, 04:15:16 PM
I think I might be able to get two loctal plugs and make some adapters to try the 3S4 in my Paramounts (though I currently run a different tube with a 10K plate load).
Offline johnsonad
Reply #14 on: December 25, 2013, 04:26:11 PM
It goes without saying but please report back with how it works out if you do try them!
