Valab 23 Steps how many steps are used?
JamieMcC · 2081
Offline JamieMcC
on: December 29, 2013, 10:14:41 AM
Just wondering how many or the range of the steps you normally use on the Valab? As I have noticed some comments on swapping out the resistors in the most used steps for higher quality resistors as a option and wondered if this would work or create issues surly it cant be as simple as it seems?
Reply #1 on: December 29, 2013, 11:04:40 AM
This question doesn't really have an answer.  Let's say I have a Valab attenuator and a source that puts out 5V.  I'll probably only use maybe the first couple of steps.
Maybe you have USB powered DAC hanging off your computer, or you're streaming music from your cell phone.  Either one will probably be ~2V, meaning you'll need to crank the control up a bit.
This also assumes that the two instances are using the same pair of headphones, which will also influence where your level control is set.
