defective part in kit
bgf · 4578
Offline bgf
on: January 24, 2014, 09:54:16 AM
Started putting my kit together one of the four pin tube sockets does not fit in the hole.  It is too large.  Tried a little wax but did not want to force it.  Any suggestions.   Thanks.
brent fauss
Reply #1 on: January 24, 2014, 10:53:27 AM
We can send you a replacement if necessary. Unfortunately, those sockets have grown by over 1 mm in the last two years. If you're in a hurry, a round file can be used to enlarge the hole.
Offline bgf
Reply #2 on: January 24, 2014, 01:02:02 PM
i am not i a hurry have the monoblock kits to do also.  i will wait for a new part thanks.  do you have my address??
brent fauss
Reply #3 on: January 24, 2014, 01:13:55 PM
Can you shoot an e-mail to:
replacementparts(At)bottlehead(dot)com?
That will get you in the queue for a new socket.
Sincerely,
Paul
Offline STURMJ
Reply #4 on: January 24, 2014, 07:47:20 PM
I have use a rat tail file, like Paul suggested. Just keep working the opening until it fits (did not take me long)
Offline Chris65
Reply #5 on: January 25, 2014, 12:57:29 AM
Same issue here, one 4-pin socket was a perfect fit, the other is way too large.
Also, one 9-pin socket was too large for the hole & the same for one of the 9-pin sockets on my Reduction.
I'm reluctant to file out the hole as it then gets quite close to the mounting screw hole.
I have a bunch of 9-pin sockets from ebay, so just found ones that would fit. So, just ordered some of the 4-pin sockets as well, they're cheap enough at about $2 each.
Reply #6 on: January 25, 2014, 08:04:26 AM
That's good to know on the 9 pin sockets.  I can run through our stock of sockets to see if yours was just a random problem, or if I need to enlarge the chassis hole.
Offline Chris65
Reply #7 on: February 10, 2014, 01:30:53 PM
Got the 4-pin sockets from China today. All are a perfect fit in the BeePre chassis plate, & look a little better quality than the supplied ones.
Reply #8 on: February 10, 2014, 06:29:21 PM
I did end up enlarging the 4 pin socket holes on our kits up another 0.5mm.  Most of our 4 pin sockets fit, but most of them were pretty tight.  (A year ago, they would slip in quite easily)
Offline Chris65
Reply #9 on: February 11, 2014, 04:56:08 AM
Have you checked out the 9-pin sockets as well? As I mentioned I had 2 that would not fit without modification.
Offline aroide
Reply #10 on: February 16, 2014, 03:47:11 AM
for me 9-pin sockets were fine, and 1 4-pin needed a small amount of filing.  It literally took me 1 minute of filing and it fit nice.  No sharp edges or burrs left.  I used a chainsaw sharpening file.
Mac mini running Roon->
Mytek Brooklyn DAC+->
Darwin Truth RCA IC->
BeePre (BeeQuiet,  Mundorf Ag/Au/Oil, Sophia Royal Princess 300B)->
Audioquest Colorado->
Rogue Audio Atlas Magnum amp (Psvane small signal tubes, KT150s)->
Audioquest Gibraltar-speaker cables>
Magnepan 1.7 & REL T-5
