HUGE channel imbalance
Tonydatigerr · 6615
Reply #15 on: January 31, 2014, 06:05:46 AM
Is there a diode checking setting?  Most of the time, this is a special position on the meter.
Offline Tonydatigerr
Reply #16 on: January 31, 2014, 11:44:36 AM
There is a diode checking setting.
Reply #17 on: January 31, 2014, 01:40:44 PM
On the diode check setting and the probes in the correct positions, most meters will actually illuminate our LED's.
Reply #18 on: January 31, 2014, 03:18:35 PM
Well, I ended up snapping the lead to the working LED trying to manipulate it into a position to see if I could actually get a reading. I tried getting a reading on the other LED and was still not successful (placing negative lead to negative side of the diode and positive to positive). Where can I buy replacements over the weekend?
Reply #19 on: January 31, 2014, 03:45:58 PM
On my meter, the probes happen to go the other way.  This may also be the case for your meter.
I have never seen the HLMP-6000 for sale in any store.  We can, however, mail you some.
Reply #20 on: January 31, 2014, 04:53:39 PM
Tucker Electronics, in 1996 or so. I bought them all.  ;)
Reply #21 on: January 31, 2014, 05:33:36 PM
Should I email the replacementparts address to get this sorted out?
Reply #22 on: February 04, 2014, 12:03:47 AM
They are available from Mouser and probably Digi-Key, Newark and maybe Allied.  Be certain the ones you order have leads and are not SMD.  I made that mistake first.
« Last Edit: March 31, 2014, 03:28:35 AM by Grainger49 »
